    Hi
    Just started with VOB2MPG Pro. Seems quite easy but whatever I do I have no sound when played back through Windows Media Player. There is sound in the preview on VOB2MPG but doesnt seem to be in the MPEG.
    Obviously i am doing something wrong.
    Thanks for any help
    John
  2. Member ChrissyBoy's Avatar
    What does MediaInfo say about the mpeg?
    Did you choose an audio stream or go with the default? Either way what is the audio type? (in the audio dropdown)?
    Hi
    Thanks for replying. I have tried the default and the French. Makes no difference
    Mediainfo says
    MPEG-PS: 770 MiB, 17mn 18s5 782 Kbps (8 200 Kbps), 720*576 (16:9), at 25.000 fps, MPEG Video (PAL) (Version 2) (Main@Main)192 Kbps, 48.0 KHz, 1 channel, AC-3
    Hi
    I forgot Audio type is Ac3 One channel
    John
  5. Member ChrissyBoy's Avatar
    One channel AC-3.... Never seen that!
    Anyway - may i suggest installing AC3Filter to see if that resolves it for you?
    Hi
    Thanks for your help. I am encoding DVD as a have a new HTPC an Asrock 330 with windows 7. If I use media center on this an access the File over the network then the sound is Ok!!
    Any idea why this is the case.
    I will try AC3 Filter on my main PC and let you know what happens
    Thanks again
  7. Member ChrissyBoy's Avatar
    Win 7 will play AC3 by default. XP will not - you need the right codec (which is where AC3Filter comes in )
    Hi
    Thanks for your help seems to work ok now.
    Regards
    John
  1. Can't get sound from MPEG in F.C.
    By Tom in HD in forum Mac
    Last Post: 14th Jan 2010, 23:40
  2. IFO > MPEG OR AVI = No Sound on Pc but extorted /fuzzy sound on TV
    By chocolate_brownie in forum DVD Ripping
    Last Post: 25th Feb 2007, 21:10
  3. Replies: 8
    Last Post: 11th Apr 2005, 16:22
  4. XVID to NTSC mpeg in tmpgenc - No sound in the finished mpeg
    By propagandhi in forum Video Conversion
    Last Post: 9th Apr 2005, 12:17
  5. MPEG W. SOUND BURNED = NO SOUND !?!
    By dawolf42 in forum Authoring (VCD/SVCD)
    Last Post: 9th Jan 2002, 10:22
About   Advertise   Forum   RSS Feeds   Statistics   Tools
