VideoHelp.com Forum
Results 1 to 10 of 10
    Hi experts: I accidentally formatted my computer. I recovered some video clips, the computer can play them but I can't author them, I would like to put them to a DVD. I've used TMPGnc, DVD2AVI, ... Please advise!
    You can play them in what ?
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Using what ?
    Some recovery programs are inferior and recover the files incorrectly causing these issues
    I use Windows Media Player, PowerDVD, RealPlayer to play the damaged clips. Most recovered clips could be made to a DVD by using TMPGnc DVD Author.
  5. Mod Neophyte Super Moderator redwudz's Avatar
    What exact errors does TMPGEnc report? I imagine the files may have breaks in them. You would have to repair those first, usually with a MPEG editor, if that's the format they are presently in. But you might try ReJig.
    When I authored the clips with TMPGnc DVD Author, it says "This is an illegal video file". I used TMPGnc, it says "Invalid video source", I increase the Directshow Multimedia File Reader to be higher then others, it didn't help.
    Can you open it in avisynth with DirectShowSource() ? (I know, not the best option, just looking at alternatives).
    If so, you can re-encode from the script.
    I downloaded Avisynth and didn't find any application file in it.
    I used ReJig and able to make most of the VCD quality videos to work in TMPGEnc except the DVD quality videos, it could be done with DVD2AVI but TMPGEnc says it is unsupported.
  9. Always Watching guns1inger's Avatar
    Install avisynth.
    Create a new file in notepad, called openmovie.txt, and change the extension from .txt to .avs
    Edit the file in note pad, and add the line
    DirectShowSource("pathtovideo")
    Where pathtovideo is the full path to your clip - e.g. c:\temp\movie1.mpg
    Open the openmovie.avs file in virtualdub and see what you get.
    Thanks guns1inger.
    I get stuck at the procedure I TMPGEng the DVD file to VCD quality. Is there any other SW that can replace TMPGEng?
  1. SOFTWARE For restoring video
    By blacksheepdownunder in forum Restoration
    Last Post: 17th Jul 2010, 09:31
  2. Question about video restoring.
    By mark23 in forum Restoration
    Last Post: 10th Jun 2010, 16:58
  3. Restoring edited video.
    By drummer in forum Editing
    Last Post: 9th Apr 2010, 05:57
  4. Video Clips For Buttons - Format & Spec?
    By EViS in forum Authoring (DVD)
    Last Post: 19th May 2008, 08:21
  5. Enlarging and restoring video
    By Crac59 in forum Newbie / General discussions
    Last Post: 30th May 2007, 18:36
