Results 1 to 12 of 12
    I have converted .ssa subs to .srt subs and still damn letter N appears in the text almost in every line. I know I can easily spot
    N letter in WordPad clicking on Edit-Replace etc. and then I would have to make the spaces instead of N. But going thru
    all text subs then to make spaces in the right spots is a real pain in neck. Does anybody know better way around ?
  2. Member craigarta's Avatar
    Well you could try Aegisub I've used in the past to correct misspelled words from Asian DVD's in the past
  3. How did you convert it?
    In SSA subs '\N' is the line break. If your 'N's are left over from that, then maybe convert using a different program. SubResynch (included in the VobSub package) doesn't leave behind stray 'N's.
    Simply, by Subtitle Workshop. "N" has been already in an SSA subs.
    It does I have just tried this.
    Well, I'll see what is this about. I'm going to give a try.
  5. Originally Posted by manono
    It doesn't. I tested also, before I posted.
    SSA:
    Overseer, the workmen\Nare going to lunch
    SRT:
    are going to lunch
    Maybe there's something wrong with the SSA subs you created. There probably is if there's some sort of an extra 'N' in addition to the '\N'. I wouldn't know as I don't use Subtitle Workshop, but maybe you go back and create them properly this time. I'm not sure why you're blaming the conversion to SRT since you say the problem exists in the SSA subs you created.
  6. Member netmask56's Avatar
    Why can't you replace every N with a space? I just tried it on a srt file I have and (I chose the letter E) and on the replace with line I did one space. I used Notepad and it worked.
    TheVoiceIsAnotherPerson ~ http://www.openwiz.org/wiki/ProjectX ~ BeyonWiz DP-P1 PVR + LiDiC ~ Popcorn C200 ~ Samsung LA40R7 LCD TV ~ Windows 7 & MAC G4
    Its a "manual" job, no way to automate this
  8. Member netmask56's Avatar
    depends on what you mean by manual - all you have to do is Replace N with space ALL and it will flip though the entire file. You could also write a script to do a batch conversion of several files I suppose.
  9. Yeah, but the real capital 'N's will also get a space after them, something you don't want. It's a manual one-by-one job for sure. Running a spell-check might help. Better, I think, would be to go back and find out where he screwed up to get all the extra 'N's to begin with.
    Global replace "\N" with " ".
  11. But then you lose all the line breaks and you'd have to go through the SRTs line-by-line to create them again. Plus, as near as I can tell he started out with a bunch of extra "N"s for some reason. He hasn't shown us any lines of sub dialog, from either the source SSAs or the converted SRTs, so who really knows what's going on?
    I did not creat them. Have been downloaded from opensubtitles.org.
    I thought maybe after conversion to SRT an "N" will dissapear or something like that. I don't know a lot about this stuff.
    Bingo The way I did this was wrong. In the Replace box and in the field Replace with: I did just nothing. Now when I put a space/press the space bar in the Replace with: field - it does the job. However, still got some work to do like searching spots that left after "N" which begins real words (as the first letter in sentences or as the first letter in some names) but in this case it's not a big deal.
    Thank you again for your tip Sidney-man
    Here:
    with "N"
    http://i37.tinypic.com/2hd5sw4.jpg
    without "N"
    http://i38.tinypic.com/x3jaf.jpg
    Thank you all for your input guys
  1. Replies: 0
    Last Post: 12th Jul 2008, 21:50
  2. how do you get rid of hard subs? especially rmvb ones?
    By chaejunghoon in forum Subtitle
    Last Post: 12th Jun 2007, 21:24
  3. Help with making .srt subs...
    By FallenAngelII in forum Subtitle
    Last Post: 28th Nov 2005, 11:16
  4. Can see subs in .SRT but not .SUB format
    By JohnnyAmadeus in forum Software Playing
    Last Post: 19th Oct 2004, 06:02
  5. 480 * 480 vcd . How do you get rid of the letter box size?
    By ticos2000 in forum Video Conversion
    Last Post: 18th Oct 2001, 19:12
About   Advertise   Forum   RSS Feeds   Statistics   Tools
