VideoHelp.com Forum
Thread: Sony RDR-VX535
    Hello,
    I'm new here, but I have a problem.
    I just got a Sony dvd/vcr recorder combo.
    It doesn't have a turner.
    I have cable coming in, but don't have a cable box.
    Is there anyway to connect this unit so I can record TV?
    Thank-You,
    John
    I'm back to ask another question.
    If I do need a turner, or I mean cable box to record TV,
    would a digital converter that we needed for programs
    back in June work instead?
    Thanks,
    John
  3. Member hech54's Avatar
    As long as the machine has a "Line In" of some sort...you can record almost anything you want on it. If you have an old VCR lying around...use that as a tuner BEFORE the "Line In".
    I still can't believe the machine is not capable of recording broadcast television on it's own. I'd break out the owner's manual again if I were you.
    Thanks for your feedback.
    This is what my recorder has;
    Doesn't have a tuner.
    Or cable, in or out connections.
    DVD/VCR recorder combo.
    Sony RDR-VX535
    S Video---Coaxial Digital Audio Out---HDMI Out
    Set Top Box Control, Which I don't know what it is.
    Line 1---Line Out---Audio Out---Component Video Out
    Video------L-----------L------------------Y
    Audio------R-----------R-----------------Pb
    --------------------------------------------Pr
    Yellow
    White
    Red
    FrontOf Unit
    Line 2 in
    Video-------L
    Audio-------R
    Thanks,
    John
  5. Member edDV's Avatar
    Thanks,
    John
    An ATSC digital converter would work for over the air DTV with antenna but not for cable. That recorder is intended for use with a cable box or satellite receiver. It should have come with an IR device to change tuner channels.
    http://www.kiva.org/about
  1. SONY RDR-VX535 help?
    By Loader09 in forum DVD & Blu-ray Recorders
    Last Post: 9th Nov 2009, 19:05
  2. Sony RDR-RXD890
    By dixons in forum DVD & Blu-ray Recorders
    Last Post: 12th Mar 2009, 23:37
  3. Is Sony RDR-HX720 compatible with Sony HT-SS2300
    By abdul_sma in forum DVD & Blu-ray Recorders
    Last Post: 6th Nov 2008, 09:14
  4. Sony RDR-VX530
    By tvlreject in forum DVD & Blu-ray Recorders
    Last Post: 5th Mar 2008, 20:40
  5. Sony RDR-HX750S
    By LDawg in forum DVD & Blu-ray Recorders
    Last Post: 4th Oct 2007, 10:39
