Hi,
I recently got a universal remote control (URC-7556) and have programmed it to work with my TV, DVD player and have tried to do so with my cable TV media box (Thomson dc152upc02 works with Cablecom, the main cable TV provider in Switzerland) I programmed the code for the media box into the URC and was able turn the box off (which is supposed to be the test that it works) but URC can't turn the box back on nor does it change the cable channels.
The problem, I think, seems to be with the so-called "Cablecom" button on CC remote. There seems to be nothing analogous on my URC, although supposedly I can programme add'l functionality into it, if I know what exactly the button is and what the code is for the functionality. The CC manual describes the button as follows: "Cablecom button -- Switch the mediabox on or return from the menu to full screen TV of the last channel viewed." Has anyone ever encountered similar problems when programming their URC to work with their media box?
Thanks,
JW
Results 1 to 1 of 1
PC controlling a cable box (USA time warner cable)
By marcolisi in forum CapturingReplies: 2Last Post: 4th Aug 2010, 16:24 -
Applying kameleon 6 URC-8206 instructions in a OneFor All URC-8820
By garciamaki in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Jul 2010, 10:01 -
Control of Cable box via SageTV on Windows Media Center 2005
By Sierraguy in forum Media Center PC / MediaCentersReplies: 2Last Post: 8th Feb 2010, 01:31 -
Media Center WITH Time Warner HD cable box - not listed provider
By Brad Bailey in forum Media Center PC / MediaCentersReplies: 0Last Post: 8th Sep 2009, 12:58 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / HDTVReplies: 11Last Post: 28th May 2009, 12:21
