Hi all, I know how to hardcode subtitles into .avi file.
I'm using XBOX360 and struggling to watch my movies with subtitles. Xbox360 doesn't play softcoded subtitles. Is there any way to hardcode\embed subtitles to MP4 or MKV files without harming the video quality?
Results 1 to 11 of 11
I wonder if AVIDemux will work as well (though I don't know the specifics videos must be encoded to for the 360... AVIDemux has a preset for the Zune, but not the 360.)
But, yes, for hardsubbing, the subtitles must be made a part of the actual video data, so re-encoding is unavoidable.If cameras add ten pounds, why would people want to eat them?
Great guys. So this is what I understand:
1. I have to re-encode the MKV\MP4 file in order to have hardcode3d subtitles on it.
2. Re-encoding will harm the video quality.
Xbox 360 supports mp4 with 2 channel audio stream (such as stereo).Ai Haibara: I wonder if AVIDemux will work as well (though I don't know the specifics videos must be encoded to for the 360
Well my question is: is there any re-encoder that can make my MKV file as best as it can be (quality wise) and hardcode subtitles into it?
I have the Xvid4PSP installed - so a walkthrough will be appreciated! thanks!
I've been trying to do this as well. I have Handbrake but so far have not been able to embed the subtitles into the video. Does anybody have specifics on how to do it? If it can't be done with Handbrake is there specifics on Xvid4PSP? I've never used it and would rather not download and install it unless I have to and know it will work
Thanks in advance.
-Dave
I've done it successfully using Avidemux. Use these builds, they're fresh out of the oven and seem to work well. No need to install, just unzip.
http://avidemux.razorbyte.com.au/
The file to launch the app is avidemux2_qt4.exe
http://www.videohelp.com/forum/archi...t-t357763.html"Quality is cool, but don't forget... Content is King!"
The AviDemux link says I'm not allowed access to the server.
edit: I got it. Evidently it prefers you to be on the web page and click the button or the error msg was erroneous.http://www.FavesSoft.com
"I don't want to belong to any club that would have me as a member."
- Groucho Marx
You're right. Worked last night, but you know....
Does AviDemux work with other containers like MKV? I'm pretty sure I tried that tool and it only supported AVI input files. 99% of the files I want to add subs to are MKVs and I'd prefer not having to convert the MKV to AVI then re-encode the AVI with the subs.
I use AVIDemux to create AVIs with hardsubs generated from .ass subtitles from MKVs for my DVD player, all the time.
My bad. I've tried so many different tools I got confused. I've had AVIDemux forever and didn't know it could deal with MKVs, but it's currently encoding a test video which I'm sure will work great. Thanks for the help.
Hardcode MKV subtitles and keep font etc?
By MrNathanF in forum SubtitleReplies: 3Last Post: 7th Feb 2012, 16:07 -
How to hardcode .sup subtitle file to a mkv movie?
By CodeGEN in forum SubtitleReplies: 5Last Post: 1st Dec 2011, 12:02 -
Hardcode .srt subtitles to .mkv file without loss of quality
By bloodcell in forum SubtitleReplies: 3Last Post: 2nd Jun 2011, 23:28 -
How do i hardcode SUB to a MKV file
By tjgrindsted in forum Blu-ray RippingReplies: 10Last Post: 21st Jun 2010, 11:38 -
It seems impossuble to hardcode subs in an mkv file
By jagojon3 in forum SubtitleReplies: 11Last Post: 27th Apr 2010, 10:04
