VideoHelp.com Forum
    Hi guys
    I hope u guys can help me out here, i bought Extendet Edition of LOTR - Fellowship of the Ring (R1), and i wanna put some extra subtitles on it, keeping original size of the movie.
    Well the prob is everytime i Remux my files back togheter, there are missing some of the movie in the end of the movie, Movie and Audio are in Sync, as far as i can hear....
    I use PgcDemux for demuxing and MuxMan for Remuxing, i have tryed to put back toghter the movie in DVDLab pro also with same issue...
  2. Member hech54's Avatar
    R2 subs and R1 subs together on one new disc?
    yup, but when i remux it, it cuts off 10 sec of movie in the end of the movie...
    The Subs are resync with the R1 ones and ready....
    I Think the problem is that the Movie is in NTSC (DF), so now i try to make it Pal with ConvertXtoDVD
    I'll tell u how it dit go, l8er today....
    It worked with the coding the movie to Pal from NTSC (DF), now the movie plays all the way and it don't cut the last 10 sec away
    So I dit following ->
    1: Convert the Movie with ConvertXtoDVD, and i set the Format to Pal.
    2: Demux the Movie that came out of ConverXtoDVD with PgcDemux
    3: Reatured it in DVDLab pro (Best program to set the subtitles correct) (Tahoma 20, Smooth Max, with Margins at 35)
    4: Opent the Original Ifo file with IfoEdit to get the correct times for Chapters (Exept the last Chapter)
    5: Compiled the project in DVDLab
    6: Burned to DVD
    7: Enjoyed the movie with the Custom Subs
  1. Audio/video out of sync after demux-remux
    By CarryNL in forum Subtitle
    Last Post: 14th Sep 2011, 14:31
  2. Replies: 3
    Last Post: 28th Jan 2010, 11:43
  3. Replies: 3
    Last Post: 13th Jan 2010, 08:41
  4. Demux mkv -> remux Divx
    By nsx3000 in forum Video Conversion
    Last Post: 15th Sep 2009, 09:12
  5. can not remux after demux
    By volam in forum Editing
    Last Post: 19th Mar 2009, 15:36
