Been using several programs to stream my blu ray from my pc to the PS3. Using java ps3 media server. I normally rip my movie using makemkv. I then take the mkv file and load with tsMuxer gui. My problem is with VC-1. I believe I have to trascode the video with Mencoder in order to stream. But when I get a movie that has VC-1 I get major lag. I even try to split the files into smaller size roughly around 3-6 gb, even with a small file I still get lag and the buffer on the status tab is always empty on Java PS3 media server. Is there any other software I could use that will support streaming on VC-1 movies. I get a unsupported video code error when I try loading the file into mkv2vob. My bottleneck is my cpu which is p4 2.8 with 2gb of ram. My ps3 and computer are both wired to my Dlink dir 655 gigabit ethernet. I know if I upgrade to a faster system it will help, but I dont think its worth it in my situation. Thanks
Thread: VC-1 and streaming on PS3
Maybe just reconvert it to h264. Use Ripbot264.
Streaming to PS3 from external HD
By anubisjazz in forum Video StreamingReplies: 5Last Post: 12th Sep 2009, 23:58 -
Streaming to PS3
By thekid138 in forum Video StreamingReplies: 8Last Post: 29th Jun 2009, 22:38 -
Streaming BD to PS3 – is it that good?
By ukchevy in forum Blu-ray RippingReplies: 7Last Post: 17th Mar 2009, 19:07 -
m2ts (vc-1) streaming to ps3?
By Browncoat in forum Media Center PC / MediaCentersReplies: 4Last Post: 16th Jan 2009, 02:06 -
Streaming from pc to ps3
By Peterrrrr in forum Media Center PC / MediaCentersReplies: 1Last Post: 17th Nov 2008, 12:42
Statistics
Newest guides
Latest tool updates
New media comments
