VideoHelp.com Forum
    I'm trying to stream Live TV over a netwotk to 4 or 5 PC's. I've seen the very useful guided on this site but i think i've bought the wrong card!
    The card i purchased is a Kworld Plus TV PE355-2T Dual DVB-T PCI-Express card. but am having no luck with getting it to work with any of the suggested streaming software.
    Could anyone recommend a card thats capable of doing the network streaming this got a budget upto £60.
    Thanks in advance
    WHat tools have you tried? I would tyr VLC Media PLayer and JTVLAN. They should work with most dvb cards.
    Hi Baldrick
    thanks for your quick reply!
    I've followed your guide using the Windows media 9 encoder pack - the unreal media stream VLC and star media serverbut i've had no luck at all. The card isn't seen by any of the software. i know the card is installed properly as i've benn watching tv on it!
    The card is capable of recording to Hard Drive using the software that came with it - Arcsoft TotalMedia.
    Ive not tried JTVLAN software though.
    The card only has a tv in and no TV out does this make any difference?
    I've tried the JTVLAN software and am still having no luck.
    can you recommend a card that would do the job streaming with the windows media player 9 encoder??
    thanks in advance
    Here's something else > Streaming dvb
    Ive already tried it with the Fission twin dvb-t (sold via aldi's in au) ... google search error = alt-dev_bda2driver.rar (follow the readme) and was up and running
    Almost forgot the link I got that rar archive from > here ... tested with avast, clean / no password.
    Incase some ask ... this archive is for ALTDVB
    hi BJ's thanksa for the link but i cant seem to find the version of the ALTDVB software the article is refering to (Version 2) the Altdvb website has been suspended so i cant get to download anything from there.
    the 2.2 version didnt seem to have the network srv files that it refered too
    Think i'll have to bite the bullet and get a new card - anyone recommend a Capture card that i can use to stream live TV to 4 or 5 PC's running XP?
    been recommended this:
    hauppauge - WinTV HVR-1300 PCI DVB-T Receiver / Analogue TV Tuner / Video Input Adapter
    do you thimk it will do the job??
  1. Streaming Digital TV Over A Network
    By minchjp in forum User guides
    Last Post: 2nd Jan 2011, 11:09
  2. ffmpeg network streaming
    By lusky in forum Video Streaming
    Last Post: 23rd Aug 2010, 07:04
  3. Samsung BD-p1600 - Streaming from Network
    By aiannar974 in forum DVD & Blu-ray Players
    Last Post: 4th May 2010, 18:16
  4. Streaming over a network, what format?
    By ripit in forum Video Streaming
    Last Post: 28th May 2008, 06:39
  5. Replies: 16
    Last Post: 21st Oct 2007, 22:19
