Hi, I'm trying to make a 2-CD-R SVCD (with TMPGen 12-h) from a DivX movie I downloaded, after it gets past a certain part (while encoding with TMPGen) the picture is scrambled, like big color blobs moving around, can't make out the picture, but can hear the sound.
I've tried using the 2 pass and also constant quality with the average bitrate (2147), and both do the same.
I've watched the DivX all the way through and it's great quality (xmen)
Any suggestions?
<font size=-1>[ This Message was edited by: P-Tingles on 2001-07-24 11:52:15 ]</font>
Thread: scrambled picture
Try opening it in Virtual Dub... and make a Direct Stream Copy of the movie... and try to encode that one. Not sur ethis will help though.
By the way.. you know you can't watch MPEG-2 files in the normal Windows Media Player huh? You need a DVD software Player... check out the tools section for that.
Thanx/
Lars
Thanks for replying!
Before I seen your reply I tried to resize it with VirtualDub so TMPGenc would not have to,
when it got to that same spot I got an error [ICDecompress], so I tried watching the DivX again, and at that spot it stops right there, but then picks back up again about 2 min. later.
I tried direct stream copy, but it did not fix it, so I just cut out the bad 2 min., seems to be OK now.
I have a DVD software player that came with my ATI AIW, but when I click open the SVCD or MPG, the normal windows media player opens it and plays them fine.
ANYDVDHD BD+ frames may be scrambled?
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 21st Sep 2011, 20:43 -
Digihome backup scrambled TRPs
By nightskystar in forum DVB / HDTVReplies: 0Last Post: 6th Nov 2009, 14:59 -
Scrambled DVD
By thepopsicle in forum Software PlayingReplies: 3Last Post: 10th Jun 2009, 13:34 -
Scrambled DVD Playback
By shteeve in forum Software PlayingReplies: 2Last Post: 15th Dec 2008, 12:40 -
Scrambled picture from tv-out
By bizzle_613 in forum Media Center PC / MediaCentersReplies: 2Last Post: 7th Mar 2008, 08:36
Statistics
Newest guides
Latest tool updates
New media comments
