    Hi,
    I want to make a dvd with episodes of tv shows that are in avi and I want to have a menu that allows you to pick the episode you want and I also want to add switchable subs. Also the main menu screen I want to have a still picture and music playing in the background, with the episodes there to choose from.
    What would be the best programme to do all this?
  2. Man of Steel freebird73717's Avatar
    Easy way try avstodvd or dvdflick
    Harder way but you have much more control over the final product would be to learn to encode video and audio separately and author your dvd just the way you want it in guifordvdauthor
    Donadagohvi (Cherokee for "Until we meet again")
    My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
    Thanks for your response, I used dvdflick but that only lets you choose menu's from a list, I want to be able to make my own menu's and add an audio track to the menu. I want to add my own image and choose fonts and so on.
  4. Man of Steel freebird73717's Avatar
    Then your best bet is either to look at payware products like ulead dvdworkshop or tmpg dvdauthor or learn how to do it the manual way with freeware.
  5. GuiforDVDAuthor with a seperate encoder
    Yep, DVDWS is what I'd use for the authoring. Guide for using Ulead DVD Worshop 2 here.
    But you have to encode the video/audio before authoring.
    For that, I suggest using ConvertXToDVD. Yes, it makes a "DVD", but you can still easily extract the encode MPEG's. Burn to an ISO file in ImgBurn, load DaemonTools or GizmoDrive to load the ISO, and then rip the video using DVD Decrypter.
    It takes a few steps to do what you want, but it's not too hard, and it can be done.
  7. AVStoDVD Author _MrC_'s Avatar
    AVStoDVD should suit your requirements.
    Bye
    MrC
    AVStoDVD Homepage
  1. converter programme
    By VaGaBoNd in forum Video Conversion
    Last Post: 27th Feb 2008, 05:33
  2. Which programme do i need?
    By harrypickle in forum Newbie / General discussions
    Last Post: 21st Feb 2007, 09:56
  3. Cant get programme to work
    By streetwise_uk in forum SVCD2DVD & VOB2MPG
    Last Post: 18th Mar 2006, 13:25
  4. looking for a programme
    By sandra in forum DVD Ripping
    Last Post: 13th Apr 2002, 21:51
About   Advertise   Forum   RSS Feeds   Statistics   Tools
