It won't play the avi files I put on the usb drive, but it plays the other ones I put on there...(yes its fat32)
I am using the firmware from the philips website, I want to upgrade to the ones everyone links to on the forum but i have no idea which one to use as there are multiple to pick from
this is the dvd player i have
model
DVP5992/37
S/N
KX1A0820354302
which firmware do i get from the guy makin those firmwares
Could you clarify what you mean by "the other ones I put on there"?
I've been able to play Xvid AVIs with no problems for years, both from a USB stick and a DVD+RW. Does it play some AVIs but not others?
AVI is a container. A logical "box" that can contain video and audio compressed (or not) with any of a number of codecs. The Philips players only support a few video codecs like Divx and Xvid. They do not support many others like MJPEG, DV, and uncompressed RGB. Use MediaInfo or GSpot to determine what codecs are used in your AVI files.
New Philips DVP5992 DVD player with USB 2.0 feature!!
By agidol in forum DVD & Blu-ray PlayersReplies: 173Last Post: 30th Jul 2011, 10:25 -
Philips DVP5992 Picture Discoloration
By i am a hobo in forum DVD & Blu-ray PlayersReplies: 5Last Post: 18th Mar 2011, 21:01 -
DVP5992 Philips sound issue
By udidwht in forum DVD & Blu-ray PlayersReplies: 11Last Post: 21st Nov 2010, 21:58 -
DVD Player won't eject. Philips DVP5992/37
By pops49 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Sep 2009, 16:59 -
Philips DVP5992 & PAL DVDs
By kinemax in forum DVD & Blu-ray PlayersReplies: 5Last Post: 21st Feb 2009, 11:03
Statistics
Newest guides
Latest tool updates
New media comments
