I'm trying to convert .m2ts ( Blu-Ray File ) to .mkv using RipBot v. 1.14.5. After about 4 - 5 hours of converting, it says the conversion is complete but no file. I then look in job1_log.txt and get the following:
I'm a noob when it comes to this, so I'm not really sure where the problem lies... I do notice that its saying at the begining 'Can't create encoder!' then at the end it seems its having a problem with the .aac file.Code:C:\>"C:\Users\Frank\Desktop\RipBot\tools\bepipe\bepipe.exe" --script "import(^C:\Users\Frank\AppData\Local\Temp\RipBot264temp\job1\job1.avs^)" | "C:\Users\Frank\Desktop\RipBot\Tools\enc_aacPlus\enc_aacPlus.exe" - "C:\Users\Frank\AppData\Local\Temp\RipBot264temp\audio.aac" --lc --cbr 131072 *************************************** BePipe by dimzon *************************************** Script used: # BEGIN import("C:\Users\Frank\AppData\Local\Temp\RipBot264temp\job1\job1.avs") # END Scanning for Audio Stream... Found Audio Stream Channels=7, BitsPerSample=16, SampleRate=48000Hz Writing Header... Writing Data... 0%******************************************************************** * AACPlus v2 Encoder (using Winamp 5.2 enc_aacplus.dll) * Source timestamp Mon May 15 17:24:26 2006 * Build May 15 2006, 17:24:35 ******************************************************************** * NOTE! enc_aacplus.dll must be into executable directory * get it from Winamp 5.2 plugins directory * tested on Winamp 5.2 Release Feb 23 2006 Full (Not Pro) version) ******************************************************************** Input file: - Output file: C:\Users\Frank\AppData\Local\Temp\RipBot264temp\audio.aac SampleRate: 48000 ChannelCount: 7 BitsPerSample: 16 Bitrate: 160000 ChannelMode: Multichannel Encoder: AAC-LC Can't create encoder! Done! C:\>"C:\Users\Frank\Desktop\RipBot\tools\avs2yuv\pipebuf.exe" "C:\Users\Frank\Desktop\RipBot\tools\avs2yuv\avs2yuv.exe" "C:\Users\Frank\AppData\Local\Temp\RipBot264temp\job1\job1.avs" -raw - : "C:\Users\Frank\Desktop\RipBot\tools\x264\x264_x64.exe" --pass 1 --bitrate 1024 --stats "C:\Users\Frank\AppData\Local\Temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 149736 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "C:\Users\Frank\AppData\Local\Temp\RipBot264temp\video.264" - 1920x1080 : 2 x264 [info]: 1920x1080 @ 23.98 fps x264 [info]: using SAR=1/1 x264 [warning]: VBV bitrate (25000) > level limit (20000) x264 [info]: using cpu capabilities: MMX2 SSE2Fast FastShuffle SSEMisalign LZCNT x264 [info]: profile Main, level 4.0 C:\Users\Frank\AppData\Local\Temp\RipBot264temp\job1\job1.avs: 1920x1080, 10000000/417083 fps, 149736 frames x264 [info]: frame I:1984 Avg QP:23.86 size: 37068 x264 [info]: frame P:74522 Avg QP:29.83 size: 6628 x264 [info]: frame B:73230 Avg QP:29.84 size: 3158 x264 [info]: consecutive B-frames: 21.9% 30.9% 15.4% 31.8% x264 [info]: mb I I16..4: 83.2% 0.0% 16.8% x264 [info]: mb P I16..4: 15.6% 0.0% 0.0% P16..4: 12.8% 0.0% 0.0% 0.0% 0.0% skip:71.7% x264 [info]: mb B I16..4: 1.3% 0.0% 0.0% B16..8: 8.8% 0.0% 0.0% direct: 3.7% skip:86.2% L0:36.5% L1:57.8% BI: 5.7% x264 [info]: final ratefactor: 29.06 x264 [info]: direct mvs spatial:74.5% temporal:25.5% x264 [info]: coded y,uvDC,uvAC intra: 9.7% 21.0% 3.3% inter: 2.0% 1.9% 0.0% x264 [info]: i16 v,h,dc,p: 40% 29% 15% 15% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 20% 19% 22% 8% 7% 6% 7% 6% 5% x264 [info]: kb/s:1023.14 encoded 149736 frames, 19.35 fps, 1023.14 kb/s C:\>"C:\Users\Frank\Desktop\RipBot\tools\avs2yuv\pipebuf.exe" "C:\Users\Frank\Desktop\RipBot\tools\avs2yuv\avs2yuv.exe" "C:\Users\Frank\AppData\Local\Temp\RipBot264temp\job1\job1.avs" -raw - : "C:\Users\Frank\Desktop\RipBot\tools\x264\x264_x64.exe" --pass 2 --bitrate 1024 --stats "C:\Users\Frank\AppData\Local\Temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 149736 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "C:\Users\Frank\AppData\Local\Temp\RipBot264temp\video.264" - 1920x1080 : 2 x264 [info]: 1920x1080 @ 23.98 fps x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast FastShuffle SSEMisalign LZCNT x264 [info]: profile High, level 4.0 C:\Users\Frank\AppData\Local\Temp\RipBot264temp\job1\job1.avs: 1920x1080, 10000000/417083 fps, 149736 frames x264 [info]: frame I:1984 Avg QP:25.11 size: 30719 x264 [info]: frame P:74522 Avg QP:32.27 size: 7214 x264 [info]: frame B:73230 Avg QP:33.69 size: 2744 x264 [info]: consecutive B-frames: 21.9% 30.9% 15.4% 31.8% x264 [info]: mb I I16..4: 47.6% 49.3% 3.1% x264 [info]: mb P I16..4: 5.1% 3.4% 0.1% P16..4: 19.7% 1.4% 1.3% 0.0% 0.0% skip:68.9% x264 [info]: mb B I16..4: 0.2% 0.2% 0.0% B16..8: 21.8% 0.1% 0.2% direct: 0.3% skip:77.2% L0:37.1% L1:62.4% BI: 0.5% x264 [info]: 8x8 transform intra:41.5% inter:90.0% x264 [info]: direct mvs spatial:65.3% temporal:34.7% x264 [info]: coded y,uvDC,uvAC intra: 17.5% 28.0% 4.4% inter: 3.1% 2.6% 0.0% x264 [info]: i16 v,h,dc,p: 44% 31% 7% 18% x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 14% 37% 5% 6% 6% 6% 5% 5% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 21% 21% 22% 6% 8% 7% 7% 5% 4% x264 [info]: ref P L0: 76.2% 13.8% 10.0% x264 [info]: ref B L0: 81.4% 18.6% x264 [info]: kb/s:1024.08 encoded 149736 frames, 16.68 fps, 1024.08 kb/s C:\>"C:\Users\Frank\Desktop\RipBot\tools\mkvtoolnix\mkvmerge.exe" -o "C:\Users\Frank\Desktop\00002.mkv" --title "00002" --default-duration 0:24000/1001fps -d 0 -A -S "C:\Users\Frank\AppData\Local\Temp\RipBot264temp\video.264" --language 0:und -a 0 -D -S "C:\Users\Frank\AppData\Local\Temp\RipBot264temp\audio.aac" --chapters "C:\Users\Frank\AppData\Local\Temp\RipBot264temp\job1\chapters.txt" mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06 Error: The source file 'C:\Users\Frank\AppData\Local\Temp\RipBot264temp\audio.aac' could not be opened successfully, or retrieving its size by seeking to the end did not work. ------------------------- Elapsed Time: 04h:39m:55s
All of my other conversions using RipBot are working fine. It just seems like this particular conversion is an issue. Is it something that needs to be addressed in RiptBot or could it be that I have a bad set of .m2ts files?
Please post blu-ray ripping and blu-ray to conversion in our blu-ray forum. Moving you.
Try google for "Can't create encoder! " and see if you get any ideas.
Has it worked with any blu-ray source? And you probably don't have to reconvert the video again, check the C:\Users\Frank\AppData\Local\Temp\RipBot264temp folder and see if you see any 264 file.
If think the problem is with number of audio channels
>>> ChannelCount: 7 <<<
Could you send me 50 MB sample (m2ts file - Use DGsplit) to www.mediafire.com
I appologize... I wasn't really sure where to post it. I'll remember for next timeOriginally Posted by Baldrick
I tried that... And either its my noobness ( lack of understanding ) or a lack of information with the same problem I have. I couldn't find a fix or information. But like I said, its probably due to my inexperienceOriginally Posted by Baldrick
Yes, I just got done ripping another Blu-Ray using the same settings and it worked fine. Infact, out of the 30+ I've done so far, this is the only time I've run into a problem.Originally Posted by Baldrick
I found the 'video.264' file. What do I do with it now?Originally Posted by Baldrick
I'll download DGSplit and give it a go. Should I use DGSplit to make a 50MB file from the m2ts file that has the main movie on it?Originally Posted by Atak_Snajpera
RipBot Problem - avi to mkv
By SmokerBamboo in forum Video ConversionReplies: 13Last Post: 2nd Apr 2012, 19:56 -
Problem Converting from MKV to M2TS
By eleusis211 in forum Video ConversionReplies: 5Last Post: 31st Mar 2012, 21:13 -
Problem COnverting AVI to MKV using Ripbot
By NA3R in forum Newbie / General discussionsReplies: 6Last Post: 24th Feb 2010, 07:11 -
Ripbot 1.14.6 is generating errors when loading a m2ts file
By playitagain_sam in forum Blu-ray RippingReplies: 0Last Post: 29th Dec 2009, 09:59 -
Problem converting mkv to m2ts (for PS3)
By scift in forum Video ConversionReplies: 8Last Post: 16th Dec 2008, 17:22
