VideoHelp.com Forum
Results 1 to 15 of 15
    When trying to read MP4 video file coded with H264 at 1280x576 if the file is short (30-35Mb) there is no problem but if it is a complete 2h video (1,2-1,5Gb) compressed with the same parameters and codec it gives an error.
    Is there a limitation on file size for the MP4 H264 codec?
    TNX
    No limitation on file size, unless the storage system is using FAT32, then the limit is 2GB - but this isn't a limitation of h.264 or .mp4 container
  3. I'm a Poll Super Moderator johns0's Avatar
    Thought max file size on fat32 is 4gb.
    Ben Johnson-I didnt take any stereos!
    Yes it is, my mistake
    But my 8GB DiscOnKey is NTFS system and it's steel not working, and the MP4 file is 2.3 GB (less than the limit).
    So it's probably another reason. What software did you use? What settings? What error message?
    For converting - Format Factory (MKV to MP4). I used the same setting in both files (35 MB that work and 2.3 GB that dont work).
    The codec is AVC (H264) High@L4.1
    The TV read only the small file and not the big file.
    use mediainfo (view=> text) on your file post the information back here
    use yamb and cut your file to <2GB just to test and see if it makes a difference
    General
    Complete name : C:\Users\Omer\Videos\Monsters_Full_1280.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 2.31 GiB
    Duration : 1h 34mn
    Overall bit rate : 3 508 Kbps
    Encoded date : UTC 2009-11-11 15:21:44
    Tagged date : UTC 2009-11-11 15:23:59
    Writing application : mp4creator 1.6.1d
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : No
    Format settings, ReFrames : 1 frame
    Codec ID : avc1
    Duration : 1h 34mn
    Bit rate mode : Variable
    Bit rate : 3 379 Kbps
    Width : 1 280 pixels
    Height : 544 pixels
    Display aspect ratio : 2.35:1
    Original display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 23.976 fps
    Minimum frame rate : 23.974 fps
    Maximum frame rate : 23.981 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.202
    Stream size : 2.23 GiB (96%)
    Tagged date : UTC 2009-11-11 15:23:37
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 1h 34mn
    Bit rate : 125 Kbps
    Maximum bit rate : 268 Kbps
    Channel(s) : 2 channels
    Channel positions : L R
    Sampling rate : 44.1 KHz
    Resolution : 16 bits
    Stream size : 84.6 MiB (4%)
    Encoded date : UTC 2009-11-11 15:23:56
    ^I added to my post above
    What does mediainfo say about the file that does work?
    The file that doesn't work uses a variable frame rate, that might cause problems with hardware players.
    General
    Complete name : C:\Users\Omer\Videos\Monsters_Test_1280.mp4
    Format : MPEG-4
    Codec ID : mp42
    File size : 12.9 MiB
    Duration : 30s 238ms
    Overall bit rate : 3 583 Kbps
    Encoded date : UTC 2009-11-11 23:17:08
    Tagged date : UTC 2009-11-11 23:17:09
    Video
    Format : AVC
    Codec ID : avc1
    Bit rate : 3 455 Kbps
    Height : 544 pixels
    Colorimetry : 4:2:0
    Bits/(Pixel*Frame) : 0.207
    Stream size : 12.5 MiB (96%)
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 30s 0ms
    Bit rate : 125 Kbps
    Maximum bit rate : 142 Kbps
    Stream size : 459 KiB (3%)
    Encoded date : UTC 2009-11-11 23:17:09
    Not sure... I would try cutting it smaller (<2GB) just to see if it makes a difference. It plays on the PC ok?
    yes, both files.
    I'm trying now 900 MB file...BRB
    By the way - thank u 4 helping
    900 MB file - working (with a little freezing I think)
    Is there something I can do other than splitting all my files?
    maybe convert them to other codec?
    or the problems is with the hardware player of my TV?
  1. Replies: 16
    Last Post: 25th Feb 2012, 16:20
  2. Samsung LN32D450 media player
    By purmax in forum Newbie / General discussions
    Last Post: 16th Jan 2012, 20:18
  3. Need help converting correctly for Samsung LED TV.
    By v8n3t in forum Video Conversion
    Last Post: 29th Oct 2011, 00:22
  4. Replies: 11
    Last Post: 28th Oct 2011, 05:25
  5. Can't play H264 with Media Player Classic
    By kruuth in forum Newbie / General discussions
    Last Post: 21st Dec 2008, 17:21
