VideoHelp.com Forum
    Never ran into this before with D'Flick , until new version.
    NOTE THAT I always want a DVD to begin with the main menu, as most commercially made DVDs will.
    (sure, many start with previews. My homemade discs will not include previews! yours?)
    *** Every dvd I've created has these problems;
    1) begins playing the 3rd title. OR ,
    2) might begin with 1st title , BUT upon hitting "MENU" button on remote , the disc
    jumps to the AUDIO Setup page , instead of the MAIN menu !
    You then must select "Main Menu" on the AUDIO page. Only now will you get there.
    3) Finally , reaching the Main Menu - the "Select Title" link is hidden , unless you use the "move right"
    button on the remote !! If this is meant to be clever??...... just seems really stupid ! Many will miss
    that link entirely. (dont we all have relatives and friends that wouldn't find it, unless you told them how?)
    As for the "Auto-Play Menu" selection. I have in past always checked it, and been ok.
    Is the wording incorrect ?? Taken literally , it would mean to jumpstart the DVD right to the Main Menu , I guess
    if you've not checked "start with" the audio, or subtitle menus??
    Did the author instead mean "Auto-Play DVD" ? , which might explain why my latest burns jump right to the
    1st title ........ but , in most cases the 3RD title ! ?? That's odd.
    I'm also confused here. I unticked the "Auto-Play Menu" and when I insert my DVD it starts playing the first title already. Luckily it goes right back to main menu after it has finished playing. I just want it to go right to the menu now.
  1. need help with dvdflick
    By shashgo in forum Authoring (DVD)
    Last Post: 24th Jul 2010, 00:24
  2. DVDFlick Re-Encoding
    By bolintx in forum Authoring (DVD)
    Last Post: 12th Aug 2008, 09:43
  3. help with dvdflick
    By shashgo in forum Newbie / General discussions
    Last Post: 28th May 2008, 05:03
  4. Menu and DvdFlick beta
    By marioval in forum Authoring (DVD)
    Last Post: 21st Jan 2008, 06:23
  5. no subs. using dvdflick
    By crashstorm in forum Newbie / General discussions
    Last Post: 29th Dec 2007, 10:46
