VideoHelp.com Forum
Results 1 to 11 of 11
    I was wondering if anybody knew how to rip an original blu-ray movie and compress it to fit on exactly two dual layer discs. The quality loss wouldn't be that bad and still alot cheaper than buying actual blank bluray discs. I am not sure what the exact size would be to set with a custom mb, or if any software can do this. Any answers would be greatly appreciated because I cannot find anything regarding this. Thank you.
    AnyDVDHD to rip and BD Rebuilder let you shrink. But I don't think there any easy methods to split it two dvdrs, maybe MultiAVCHD.
    And PLEASE PLEASE post blu-ray ripping in our BLU-ray Ripping forum. Moving you.
    I tried BD Rebuilder it would just stop working at a certain point. How many mb's would I have to set a custom mb for to exactly fit two dual layer discs if I were to try bd rebuilder again? Thanks.
  4. Sorry you can't use bdrb to split an original blu-ray into 2 dvd discs. You may be able to use ripbot or clown bd to do what you want, i'm not that familiar with those two programs.
  5. Always Watching guns1inger's Avatar
    I use Multi-AVCHD to do the encoding, using vcalc to get the correct bitrates. Once encoded, I use TSMuxer to join/split the m2ts files created by Multi-AVCHD into two sets, authored as AVCHD titles.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Can any one suggest a way to convert this monster of a movie
    and put it on two double layer DVD so that they will play on a
    standalone BluRay player. See mediainfo below.
    General : F:\"movie".PROPER.1080p.BluRay.DTS.x264.mkv
    Format : Matroska at 16.9 Mbps
    Length : 15 Gb for 2h 6mn 50s 274ms
    Video #0 : AVC at 14.6 Mbps
    Aspect : 1920 x 800 (2.400) at 23.976 fps
    Audio #0 : DTS at 1 536 Kbps
    Infos : 6 channels, 48.0 KHz
    Language : en
    Audio #1 : Vorbis at 80.0 Kbps
    Infos : 2 channels, 48.0 KHz
    Language : en
  7. I'm a Poll Super Moderator johns0's Avatar
    Thats a warez movie downloaded.
    Ben Johnson-I didnt take any stereos!
    I don't know if it is warez or not. It was handed to me as a challange so I passed it on to you guys for suggestions. If it turns out to be warez lets remove it and get on with something more important
  9. I'm a Poll Super Moderator johns0's Avatar
    Proper is a group name that releases mkv movies on the net,for example:Star Trek 2009 PROPER 1080p BluRay DTS x264-ESiR.
    I pulled that off google,its pretty well the same title name of proper mkv you got.
    johns0,
    I also did a google search and found the similarities very convincing. I passed this on to my source and suggested that he handle it another way and leave me out of it Thanks once again for your help.
  11. Member wulf109's Avatar
    If you check prices on newegg you can buy BD-R's for the same price as a DL DVD.
  1. DVD-R to dual layer, blu-ray or hard drive? Possible?
    By daysaf00 in forum Authoring (DVD)
    Last Post: 24th Mar 2012, 14:50
  2. Ripping Blu Ray to Dual Layer DVD?
    By gbreeze in forum Blu-ray Ripping
    Last Post: 26th Dec 2009, 22:27
  3. Replies: 18
    Last Post: 21st Sep 2009, 13:36
  4. Replies: 5
    Last Post: 5th May 2008, 16:05
  5. Do newer drives rip dual layer discs any faster?
    By Sephiroth666 in forum DVD & Blu-ray Writers
    Last Post: 21st Feb 2008, 09:40
