How do I play a movie in AVI format on my computer? Which program do I need?
Thanks!
Results 1 to 9 of 9
Go to http://www.videolan.org/vlc/ then download the sw, install and play ...
Normally, Windows ships with Windows Media Player, which should play AVI files just fine. You may need to install codecs for the video or audio encoding used in the AVI, however.
There are also a number of other players you can install, like VLC, which kevinguyen mentioned, that uses its own internal codecs, so you usually don't have to worry about installing anything else.If cameras add ten pounds, why would people want to eat them?
There are literally dozens of 100% bloateware free players that can play virtually anything you want to without installing extra codec packs that cand o more harm than good
Like suggested the simpler the better, in my opinion, all you want to do is play the video
MediaPlayer Classic
KMPlayer
These are the two that I use, and both can play virtually anything. KMPlayer tries to play everything without installing anything else and plays basically everything, AVI,WAV,RM, WMV, MP3, FLAC, etc, etc, etc, and DVD without installing anything else whereas a lot of other software looks for 'other' codec to play DVD
Thanks!! Then how do I convert it into a file that I can record onto DVD and play on a dvd player?
http://www.videohelp.com/guides?sear...or+List+GuidesOriginally Posted by tfly
Get ConvertXToDVD. That will easily convert AVI to DVD. Not free, but this one is much better than the freeware options. One of the few must-buys out there.Originally Posted by tflyAnswers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
The correct format for a movie to play on a Bluray player.
By hardhatmac in forum Authoring (Blu-ray)Replies: 6Last Post: 2nd Mar 2010, 17:53 -
Problem with Windows Movie Maker not recognising .avi format
By NP11073 in forum Newbie / General discussionsReplies: 4Last Post: 14th Sep 2008, 06:39 -
Subtitled AVI Movie File - Can't Convert To DVD Format Without Glitches
By TheGimp in forum ffmpegX general discussionReplies: 13Last Post: 19th May 2008, 00:48 -
AVI (or any other standard movie format) to DVD conversion
By marcdcx in forum ffmpegX general discussionReplies: 3Last Post: 31st Jul 2007, 10:16 -
dcr-sr42e movie cant play in computer
By meeya in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 12th May 2007, 15:25
