I was able to convert one video I had copied from my DVR, but on the 2nd one I tried, the left side of the ffmpegX box says "unrecognized". The file is in .m2t format just like the first one that worked. Any ideas?
Thread: unrecognized file?
Moving you to our ffmpegx section.
Try opening the file in MPEG Streamclip, then File > Convert to MPEG, to 'fix' the file and give it a regular MPEG header. MPEG Streamclip will give its output file a .mpeg suffix. Change that to .mpg for better support in ffmpegX. Now ffmpegX should understand your file better.
MPEG Streamclip says, "error: can't find the first video frame" when I try to convert it to MPEG.
Unrecognized .avi file
By dvm8600 in forum ffmpegX general discussionReplies: 11Last Post: 5th Mar 2009, 18:06 -
unrecognized
By merkin1 in forum ffmpegX general discussionReplies: 1Last Post: 19th Sep 2007, 16:15 -
Unrecognized format?
By Dale1990 in forum ffmpegX general discussionReplies: 6Last Post: 17th Jan 2007, 18:21 -
unrecognized/mislabeled file
By agent222 in forum Authoring (DVD)Replies: 1Last Post: 10th Aug 2005, 14:28 -
Is it me or TMPGEnc? "unrecognized file type" Arrrggg
By rrich in forum Video ConversionReplies: 2Last Post: 25th Mar 2002, 16:29
