I want to transfer ( no transcoding) 3 folders-each contains many mpeg2 clips-into bd disc with this kind of menu:
-the menu only shows 3 folders. when I click on a folder it will show the correspnding video clips.
-If the above can be done, I want to use bitmap pictures to replace the folder icons.
All responses are appreciated very much.
Thread: multiavchd, create menu?
multiAVCHD can do what you need, except the nested folders. You can 'hide' titles from the menu and this will allow you to import all files, order them and chose three which will be main titles. Then you can replace their thumbs with your images.
Laugh and the world will laugh with you. Cry and you will be alone
Thanks very much for your response.
I am still trying to work with the software. I have 5 folders, each has from 14 to 24 mpeg clips. The total is 24.5 gb. I hope all can fit in a 25gb disc. If not some clips can be removed. I have the following issues:
1/ since all clips in a folder are mpg, the software allows to join them under 1 title. I do this and I have 5 titles for 5 folders. I don't think this is what you call " hide title from the menu",right?
2/ The Thumbnail menu shows 5 titles. The XMB/Carousel/Slide menu only show 4 titlles, is it possible to show all 5 titles?
3/ How can I make each clip a chapter and have over 12 chapters per title?
4/ How can I activate the user template?
Thanks for your time.
PS: I am using the latest version 717
continue,
the multiavchd software always creates 12 equal chapters even when I did not choose this option.
when I try to create chapters manually. it didn't work correctly.
Hi,
I've been making the same question about more than 12 chapters, but any response yet!!!
Cannot get multiavchd to create menu
By Yanta in forum Authoring (Blu-ray)Replies: 0Last Post: 22nd Feb 2012, 23:29 -
How do I create DVDs in MultiAVCHD?
By holygamer in forum Authoring (DVD)Replies: 10Last Post: 3rd Oct 2011, 18:03 -
How to create a 3d anaglyph avchd using multiavchd from sbs or over/under
By yoda313 in forum User guidesReplies: 0Last Post: 26th Apr 2011, 20:21 -
multiAVCHD won't create main menu
By The Realms of Gold in forum Authoring (DVD)Replies: 2Last Post: 21st Mar 2011, 11:48 -
How can I create this very simple menu with Multiavchd?
By alc112 in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Jul 2010, 13:26
