Hey... i've followed quite a few dvd to avi conversion tutorials on here and none of them turn out too well.
XVID4PSP: works on some of my dvds, others it includes the dvd menus at the start of the video and the audiois way out of sync.
Fairusewizard 2.9: the quality for a 1.4GB avi file was HORRIBLE.
simpledivx: crahses part way though the conversion.
Handbrake: video quality was good. the aspect ratio was 4:3 instead of 16:9, even though i set the res at 16:9.
So, whats the best way to convert a dvd to avi, while keeping the 5.1ch audio?[s:f7a7a0a549][/s:f7a7a0a549]
Thread: DVD to avi issues
Welcome MoltenTesseract
1:Most common issues are created by trying to use programs with direct access to the dvd medium ... best to rip content to hard drive using DVDFab HD Decrypter ... to prevent programs from running into common issues during conversion process's use movie only feature ... and remember it needs to be updated to keep up with newer titles.works on some of my dvds
2:True enough ... and I can name a few recent release's which are border line garbage ... and they put that on dvd these days ... but this has mostly to do with settings for the encoder used.the quality for a 1.4GB avi file was HORRIBLE
3:This is why some applications work and some dont ... after a while it becomes clear on which applications to avoid for specific tasks.crahses part way though the conversion
A little bit like using the term "FREE" as part of an applications name ... it's suggestive and gives the wrong intention.
4:Use gspot to determine DAR ... if incorrect make the change in handbreaks video tabbed section4:3 instead of 16:9
This could also indicate a dvd structure which includes two different aspect ratio versions or multi-angle title.
5:a) Rip dvd in movie mode only using DVDFab HD Decrypter to hard drive ... this removes menu's, extra's, angle'sSo, whats the best way to convert a dvd to avi, while keeping the 5.1ch audio?
b) Use an appropriate application for the conversion which provides adequate features ... many available
Hey. I'm still having issues with getting good quality.
I'm now using vob2mpg to extract the mpg and feeding that into every program i can find. but for a 1.4GB movie, the quality i keep getting is far worse than the original dvd.
I've seen 'scene' releases that are 700MB and have better quality than my 1.4GB files... am i doing something wrong?
AVI to DVD issues
By tim_ver in forum Newbie / General discussionsReplies: 3Last Post: 18th Mar 2009, 08:40 -
Avi > DVD timing issues
By dragonnick in forum Authoring (DVD)Replies: 10Last Post: 29th Nov 2005, 11:25 -
Avi To Dvd Sync Issues
By westernbulldog in forum Video ConversionReplies: 4Last Post: 13th Aug 2005, 08:41 -
AVI to DVD or SVCD issues
By aragorn234 in forum Video ConversionReplies: 2Last Post: 23rd May 2004, 09:11 -
Playback of svcd to avi has more issues than dvd to avi?
By zelek in forum Software PlayingReplies: 0Last Post: 10th Jun 2002, 17:53
