    For a christmas event in my company we need live streaming of HD video material.
    We have a camera with HD component outputs. My way would be to capture this and directly stream it with VLC to the network.
    Unfortunately I can't find very much HD component capture cards in the net.
    Does anyone here have some experience with this?
  2. Member edDV's Avatar
    What camera?
    Live encoding from component may take hardware.
    What format are you streaming to?
    What bit rate?
    Quick component to h.264 consumer level hardware solution is the Hauppauge HD PVR.
    http://www.kiva.org/about
    It's some Sony HDV 1080i camera with only Firewire (not sure if live) and component output.
    The encoding unfortunately has to be done in MPEG-2 because the receiving software doesn't understand anything different. I just saw that VLC's max bitrate is 8mbit.
    I'm open for all suggestions for a different streaming server (only condition is to deliver mpeg2, ts and multicast)
    Capture card
    AVerTV CaptureHD
    It will depend if vlc can connect to the device
  5. Member edDV's Avatar
    HDV is MPeg2 at 25Mb/s and is usually available as a live stream over Firewire.
    Why is your network limited to 8 Mb/s MPeg2? That won't be HD.
  1. Component video signal->TV problem
    By nathanaa in forum Newbie / General discussions
    Last Post: 16th Jul 2007, 22:37
  2. Converting Component HD Back To Analog Signal
    By XxMistaMADDxX in forum Capturing
    Last Post: 11th Dec 2006, 15:32
  3. philips 3910 intermitant component signal
    By jwoody in forum DVD & Blu-ray Players
    Last Post: 28th Aug 2005, 15:19
  4. Best card for weak signal?
    By hovispresley in forum DVB / HDTV
    Last Post: 25th Nov 2004, 16:43
About   Advertise   Forum   RSS Feeds   Statistics   Tools
