Results 1 to 24 of 24
    Hi everyone,
    I have been trying to remember what DVD Authoring Software allows you the option of creating chapters every "n" minutes or so where "n" is the number of minutes you specify. I am pretty sure I have that program somewhere but I can't seem to remember the name of the program.
    If someone can help me here with my memory, I will really appreciate it. I must have uninstalled it from my HD but now I need it badly but don't know which one. I have tried Pinnacle Studio 9 and DVD Lab Pro 2.15 but none of them has that option.
    It will save me lot of time rather that having to install every one of them and trying it out.
    Thanks in advance for the help......
    Subhash.
    Thanks.
    Subhash
  2. Member AlanHK's Avatar
    GfD
  3. Member LJB's Avatar
    Ulead DVDMovieFactory will do that.
  4. Member MOVIEGEEK's Avatar
    Having problems ripping a DVD? Read my guide
  5. I'm a Poll Super Moderator johns0's Avatar
    Originally Posted by TJohns
    Easiest one to use to make chapters by the minutes.
    Ben Johnson-I didnt take any stereos!
  6. Unregistered El Heggunte's Avatar
    DVD Santa ?
    Seriously, I do not see the point of inserting chapter points @ every N minutes.
    Either I myself decide when and where the chapters will start and end,
    or the DVD title(s) will have no chapters at all. As everybody should know,
    a movie or a documentary is not "naturally divided" in 5-minute chapters...
  7. Member AlanHK's Avatar
    I do it to make it easier to skip back and forward, rather than having to fast forward/rewind.
    I usually run GfD's chapter editor, make equally spaced chapters (enough so they are about 3-5 minutes apart) and add one (the first) at the end of the opening credits, and the last at the beginning of the end credits.
    You really have to watch it all the way through before you can work out "natural" break points, so that's very rarely something I do. If I'm redoing a movie from a DVD, I usually duplicate the original chapter points (eg, with ChapterXtractor, PGCDemux), can just paste in the list of times.
  8. I'm a Poll Super Moderator johns0's Avatar
    DVD Santa ?
    Chapters are meant to skip quickly to a spot in a movie,having 5 minute chapters lets me click 6 times to get 30 minutes into a movie,much easier setting auto chapters than manually setting markers that take too much time to place.
    Having no chapters in a 3 hour movie would be gruesome,as to a film not "naturally being" divided into 5 minute chapters makes as much sense as a book not needing chapters.
    Exactly. Most DVD authoring apps (free or otherwise) allow you to set chapter points every 5mins or whatever interval you decide. I actually use VideoRedo with which you can set chapter points at regular intervals or wherever you decide, and it will spew out a chapter list which you can then feed nicely into Muxman for authoring. (You can author also with VideoRedo, but out of habit I tend to go for Muxman, which has never let me down re authoring).
    The new Womble EasyDVD also does chapter points very nicely/smoothly. I'm still testing this one out, and although it seems a bit limited at this moment in time it seems a rock solid performer and will no doubt improve it's abilities. I'm definitely keeping my eye on this one (bought it cheap in fact, being a registered Womble user. In fact, 10th Nov is last day to get it cheap!!!)
    Thank you all for the input.
    I totally agree. For the kind of movie I want to make DVD of, I really don't care at what point the chapters are marked. I just need to skip quickly through the movie. If I want to go to a particular point then I will skip to an approximate chapter and FF or REW from there to the exact location I want rather than to create chapters at the DVD Authoring time.
    I don't have any of the other programs mentioned here except Ulead DVD Studio. It must have been that one. I am going reinstall that and see how it goes.
    Thanks.
    Subhash
  11. Member olyteddy's Avatar
    Many, if not most DVD players have some form of 'Skip to Time', too. At least the ones I have do.
  12. I'm a Poll Super Moderator johns0's Avatar
    Thats a real pain to bring up the time and then input the the numbers and then go to that spot,much easier to skip chapters.
  13. Member MOVIEGEEK's Avatar
    Most BD players don't have this feature, I also prefer using chapters.
  14. Always Watching guns1inger's Avatar
    FWIW, DVD Lab Pro does this as well.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    I finally discovered the exact software I was trying to remember and that was Cyberlink Power Director. For some reasons I had uninstalled it from my comp and I recently installed it again and voilla, it had the feature I was desperately looking for.
    Just for the benefit of those who might be trying to do the same thing as I want to do.
    @guns1inger: Thanks for the tip on DVD Lab Pro but the DLP takes only m2v files as input (I think). That is an extra step for me and also the risk of compromising quality during conversion back and forth.
    Thanks.
    Subhash
    Hi ZQX
    Quote actually use VideoRedo with which you can set chapter points at regular intervals
    Can you please explain how you do this with VideoRedo ??
    I cannot see any option for Chapter creation or changing
    Originally Posted by zenzen1 View Post
    Hi ZQX
    Online manual:
    http://www.videoredo.net/helpdocs/en...apterMarks.htm
    There should also be a copy of it with the program on your computer. And it has a search function, which is how I found that page.
  18. Member
    Jim44 Thanks for that. Much appreciated.
    Back again !! OK I've got VideoReDo to save a Chapter text file.
    Now I wish to import the video file and Chapter text file into Handbrake to create an MKV.
    But Handbrake will only import CSV Chapter files. Another brick wall (
    1) Is there a program that will convert Chapter text files to Handbrake's CSV files ?
    2) Is there an MKV creator that will accept VideoReDo's Chapter text files ??
    Thanks in advance
    Baron
  20. Member AlanHK's Avatar
    Both formats are plain text files.
    Open in a text editor and you should be able to work out a search-and-replace or macro to convert between them.
    Or you could use Excel.
    Or post a sample of each format here and somene may be able to help you.
    This is the text file that VideoReDo outputs
    00:00:20:00
    00:00:40:00
    00:01:00:00
    00:01:20:00
    00:01:40:00
    00:02:00:00
    00:02:20:00
    00:02:40:00
    00:03:00:00
    00:03:20:00
    00:03:40:00
    (Chapters every 20 seconds for brevity)
    But how do I convert these to a CSV file that Handbrake will read ??
  22. Member AlanHK's Avatar
    Example of this kind of file?
    CSV = Comma Separated Variables. But we need to know just which "variables" it wants, and in what units, etc.
  23. Member
    Afaik Handbrake doesn't allow you to *create* chapters, but only to names chapters it has detected on a DVD.
    The .csv file that you can import in handbrake is in this form:
    1,Chapter One
    2,Chapter Two
    3,Chapter Three
    More info here: http://trac.handbrake.fr/wiki/CLIGuide
  1. Creating chapters
    By grandsire02 in forum Authoring (DVD)
    Last Post: 30th Dec 2005, 07:48
  2. Creating Chapters
    By marcopolo1 in forum Newbie / General discussions
    Last Post: 4th Apr 2004, 04:47
  3. Creating Chapters
    By sterankin in forum Authoring (VCD/SVCD)
    Last Post: 8th Dec 2002, 09:45
  4. Creating chapters
    By cangrejitoplayero in forum Editing
    Last Post: 20th Aug 2002, 04:29
  5. Creating Chapters
    By filefreak in forum Authoring (VCD/SVCD)
    Last Post: 30th Nov 2001, 02:06
About   Advertise   Forum   RSS Feeds   Statistics   Tools
