    Hi all,
    I have LG DVD player (don't know the exact model right now). Everything's fine when I try to watch movies from
    a DVD disc. However, when I try to load some movie from my USB flash drive (tried different sorts of them),
    some movies, which are 1.5 - 2 GB in size, it does not start playing. There is no error or something, just the progress
    bar keeps spinning. With smaller files everything is OK.
    Could anyone please explain that weird behaviour to me?
    Thanks!
    Movie_Snatcher
    Do your flash drives use the FAT32 or NTFS file system? NTFS is a problem on most DVD players that support USB devices. If you are using FAT32 then there might be a size limit on what the player supports or your larger files might have some encoding feature that your player doesn't like.
    As for file system, it is FAT32. Well I suspect it is some file size limit then and there is no work around..
    Thank you very much!
  1. Replies: 4
    Last Post: 30th Dec 2010, 10:43
  2. Replies: 17
    Last Post: 26th Jan 2008, 12:42
  3. Whick dvd player with usb port can play rmvb file?
    By haitang in forum DVD & Blu-ray Players
    Last Post: 19th Jun 2007, 01:31
  4. Hack to convert USB/DIVX DVD player to read from the Network
    By thrutnut in forum DVD & Blu-ray Players
    Last Post: 21st May 2007, 12:27
  5. Help! My dvd player won't read vcds anymore! read!
    By Achoo in forum DVD & Blu-ray Players
    Last Post: 6th Oct 2003, 10:48
About   Advertise   Forum   RSS Feeds   Statistics   Tools
