    Hi
    I would like to rip a dvd using RipBot264, but when I add a vob file, only that particular vob file is loaded not the complete movie. Am I doing it the wrong way?
  2. Mod Neophyte Super Moderator redwudz's Avatar
    That's confusing. RipBot is a Blu-ray converter program. I didn't know it would accept VOBs. A DVD movie consists of several VOBs. The movie file is split into 1GB VOBs. If you are converting a DVD, then there are plenty of programs to do it available.
    If you are converting a Blu-ray, then it should select the largest .m2ts file, which is usually the whole movie. But some BD's split the main movie to multiple .m2ts files. You can use tsMuxeR to combine them all together, then use RipBot to convert.
    Yes, I know it's a bluray rip application. But since it supports vob file I thought that I could use it as a DVD rip application beacuse I would like to create a mkv file of my dvd.
  4. Mod Neophyte Super Moderator redwudz's Avatar
    You might try MakeMKV. I haven't tried it, but it sounds promising.
    Hi
    I tryed the MakeMKV application and it worked just the way I wanted it , nice and easy. Had all the functions I needed and it was really fast. Thanks a million!
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    If you also want to shrink (makemkv just make a dvd without any conversion) you can use handbrake, staxrip, megui. But I think it should work with ripbot also, you may have to choose the ifo file instead of vob...but I have not tested it.
  7. Ripbot doesn't support ifo files. Therefore you can only convert the vob files. You have to find some other way to "paste" the vob's together.
  1. best rip using ripbot264
    By magmo in forum Blu-ray Ripping
    Last Post: 27th Jul 2009, 20:44
  2. DVD Shrink doesn't complete rip
    By mmyuen2 in forum DVD Ripping
    Last Post: 15th Mar 2004, 23:24
  3. Replies: 6
    Last Post: 28th Jan 2003, 19:04
  4. Is it possible to rip a complete image of a dvd?
    By krazyscotsman in forum DVD Ripping
    Last Post: 4th Apr 2002, 22:15
  5. Replies: 1
    Last Post: 19th Oct 2001, 00:25
About   Advertise   Forum   RSS Feeds   Statistics   Tools
