I want to save some videos from a dvd as mpeg files. The DVD has say 4 clips on it, and I want to be able to extract each clip to an mpeg file.
Is there any portable app that I can run from a USB flash drive to do this, without having to install or store any files on the PC?
Thanks.
DVDDecrypter will but don't expect it to handle the latest titles ... fine for older or home made
Not sure "untested" but Free DVD Ripper 1.0 ... click "jetzt starten" ... about 1.3mb's
... appears to work fine here.
Note: Appears to run from flash drive as well ... will test on another clean system.
Didn't think about DVDDec, have had that installed on my pc for years.
I can't test it until I get to the persons house though, as I don't have a dvdr in my pc as of now, which is why wanted a portable app. Hopefully it works as I'm thinking, the last time I did this, I think it was with videoredo, and that's what I'm assuming it will also do.
Anyway, thanks, will try when I can.
MacPorts + mplaver-devel -> portable .app ?
By Selur in forum MacReplies: 7Last Post: 29th Apr 2012, 08:45 -
Portable DVD Player vs Portable Video Player
By DJboutit in forum Newbie / General discussionsReplies: 8Last Post: 19th Apr 2012, 15:30 -
WinFF 1.40 portable doesn't save folder options
By jgg in forum Video ConversionReplies: 1Last Post: 19th Jan 2012, 17:24 -
Portable app for combining AVI files
By cowboyup910 in forum EditingReplies: 3Last Post: 27th Oct 2011, 02:58 -
What exactly makes an App 'portable'?
By ahhaa in forum ComputerReplies: 4Last Post: 10th Sep 2008, 12:38
Statistics
Newest guides
Latest tool updates
New media comments
