Hi, planning on getting a new blu ray rom. I just wondering what you guys recommend for a fast reader. I really dont care about a write just want one that reader I heard good things about LG now a day. I am using a friends Lite-on and its rated at 5x but its actually reading t 2.1x. My system is a P4 2.6. 2gb ram, sata 7200rpm WD. I just need a player that is reliable and at least read disc at 4x. Thanks
Thread: Looking for a New Blu ray drive
Bought a liteon 208 from Newegg about a month ago. Seems like it was just under $100. Works well. Over the years I've bought a number of liteon drives and never had a problem with any of them. The 208 is a 25gb 8x and a 50gb@6x. Seems to work at the rated speeds.
Tony
thanks for the reply. Does the read rate depend on the type of software we are using. As far as the read rate goes also depend on my other hardware such as cpu, ram, and hd speed? I dont want to spend money on a 8x player and find out that the software im using or my hardware spec is making it read at 2x. If that is the case, I would rather much spend money on a cheap 4x reader. Thanks
LG's are limited to 4.8x read on BDMV [BD-ROM(commercial blu ray movies)] get anything but 1 of themOriginally Posted by dazz87
ocgw
peaceAthlon II Propus 630 @ 3.62Ghz / 8GB DDR2 1066 5-7-7-20 / 8x BD-RW / 19TB Storage
http://forum.videohelp.com/topic368691.html
Blu-ray drive recommendation
By W_Eagle in forum Blu-ray RippingReplies: 5Last Post: 2nd Jul 2009, 14:34 -
wd tv blu ray to hard drive
By bob666black in forum Blu-ray RippingReplies: 7Last Post: 25th Apr 2009, 08:07 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05 -
First Blu-ray disc drive won’t play Blu-ray movies
By akrako1 in forum Latest Video NewsReplies: 15Last Post: 14th Aug 2006, 00:30 -
Philips goes for its first Blu-Ray drive
By roma_turok in forum Latest Video NewsReplies: 4Last Post: 10th Jun 2006, 09:50
Statistics
Newest guides
Latest tool updates
New media comments
