I have good video files I try to use to make a good dvd of but most end up with small skips or pauses or what ever you like to call it not many of them just a few but if I take the iso file created and play from daemon it plays perfectly could the issue be my dvd recorder?
curently have sony DVD RW DRU-190A.
Thread: DVDFlick burning question
...or your choice of DVD blanks.
Small skips on your computer(when you play the burned dvd) or standalone dvd player or both?
Are you making a NTSC or PAL DVD?
tried it on both baldick and have tried staples dvd+ rw and memorex rw+
Crap and Crap.Originally Posted by videodude1966
There are many variables here:
1.The media you are using is crap, try it on a Verbatim DVDR.
2.Your writer is old so make sure you have the latest firmware: http://sony.storagesupport.com/node/7073
3.DVDFlick is not the best for encoding/authoring, if the files are MPEG-2 make sure DVDFlick isn't re-encoding them(video->advanced).Having problems ripping a DVD? Read my guide
thx moviegeek would a rw version be just as good? and already updated firmware. DVDflick doesn't seem to be the issue as it creates a file that plays perfectly with daemon but I will try Verbatim didn't think that was it cause some movies worked thats why was thinking it was the recorder.
DVDFlick Re-Encoding
By bolintx in forum Authoring (DVD)Replies: 15Last Post: 12th Aug 2008, 10:43 -
help with dvdflick
By shashgo in forum Newbie / General discussionsReplies: 5Last Post: 28th May 2008, 06:03 -
no subs. using dvdflick
By crashstorm in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2007, 11:46 -
Question about DVDFlick
By acid_burn in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2007, 06:43 -
Menu with DVDFlick?
By smokies430 in forum Video ConversionReplies: 1Last Post: 4th Apr 2007, 20:36
