Hi there, hope this is the right subforum.
I want to capture a certain .wmv stream and save it as a flash file directly.
It's a fragment of a longer videostream (an interview of a longer tv show) which I want to upload as a .FLV to YouTube.
Besides not knowing how to rip it as .FLV file directly, there's the problem that I can't seem to be able to rip just this fragment (which I CAN watch seperetaly in WMP though) so I'll have to download the entire show. Orbit Downloader for instance isn't able to capture it, only the full video. So then I'll have the full .wmv file ripped (using WMRecorder), cutting out that one fragment and saving that as another .wmv (using Windows Movie Maker), and than quality worsens again by YouTube also converting it (to .flv) when uploading the fragment. The original online stream quality isn't the best already, so I don't want to convert it to .flv after ripping. I want it ripped as a .flv!
here is the link of the fragment, to watch in WMP (copy/paste in 'Open URL'):
http://cgi.omroep.nl/cgi-bin/streams...nd=0:11:47.669
and here the link to the stream online (video only plays in IE):
http://dewerelddraaitdoor.vara.nl/Vi...he=1&tx_ttnews[tt_news]=11118&tx_ttnews[backPid]=626&tx_ttnews[cat]=238
So, is there a program for ripping .wvm to your PC as .flv? Like, the same way it's possible to capture youtube (.flv) files as .avi and other file types using vixy.net.
If not, what would be the best way to have it on YouTube with as much original quality as possible?
You could try cut the wmv using asfbin, it wont reconvert the video.
To save just that fragment use WebVideoCap (you may need to fix it with AsfBin). Youtube will recompress everything, including flv, so you should upload it directly as wmv/asf, unless you get sync problems.
thanks lads, both programs seem to create the same thing, properties and video quality wise[s:93655955fe], asfbin creates a much bigger file size (85mb) than webvideocap (36mb) though.[/s:93655955fe] (made a mistake)
.flv to .wmv or wmv. to mpg
By LITEONDVD in forum Video ConversionReplies: 5Last Post: 29th Jul 2007, 19:02 -
simple method to stream from a TRV900 directly to DVD
By 8w8 in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2005, 14:49 -
How Can I Rip An Audio CD Directly to MP2?
By tygrus2000 in forum AudioReplies: 1Last Post: 13th Sep 2003, 20:35 -
rip directly from analog to dvd
By lghitis in forum CapturingReplies: 3Last Post: 20th Dec 2002, 04:39
Statistics
Newest guides
Latest tool updates
New media comments
