Hi ,
I'm back again with a new problem :
A DTS-HD file of 4,5 Gb can be encoded to ac3 using BeHappy ???
If yes , what are the settings ,coz I've already tried and gave me the following error :
< Starting job 00001.track_4352.dts->00001.track_4352.ac3
Error: BeHappy.AviSynthException: AVIFileSource: couldn't open file 'E:\Muzica\TCHAIKOVSKY\BDMV\STREAM\00001.track_435 2.dts'
at BeHappy.AviSynthClip..ctor(String func, String arg, AviSynthColorspace forceColorspace, AviSynthScriptEnvironment env)
at BeHappy.Encoder.encode() >
or this one :
< Starting job EVOB001.track_136.dts->EVOB001.track_136.ac3
Error: BeHappy.AviSynthException: AVIFileSource: couldn't open file 'E:\Muzica\RACHMANINOV\HVDVD_TS\EVOB001.track_136. dts'
Thanks !!!
I don't think so. Try instead eac3to.
thanks Baldrick !!!
but I see that's too complicated for me...too much settings to do and as you maybe already know , I'm not a specialist
( just a newbie..
There is any possibility to guide me or to explain how to encode that F**king file ? You or smbdy else.....Pls , help a poor man !!!!!
I have already tried , but all open icons runs to lower bar and remains there
It's clear ,I do not know to work with it
I use an older version of eac3to which is much less intimidating.
http://www.afterdawn.com/software/au...on_utility.cfm
Only problem I've had was the AC-3 bitrate option in 'Conversion Options' which some do not work so leave it blank.. Instead, use 'Other options' and enter a valid bitrate as -xxx.
@Megahurts
Many thanks !!! indeed is less intimidating ..I've tasted it but gave me the same error like the previous ones
I need a specialist to guide me for few steps at the beginning....maybe I'm doing some mistakes in settings , or....
Still I'm waiting that..help
about this version , can anyone tell me which icon should I use for launch the exe ???
Anyone can not really help me ?
A toturial or something like that , don't you have any explanations ???
something simple, for dumps like me, so ....sorry for my insistence but I'm in a hurry
Sorry ,I'm back again ,coz nobody want to help me with a tutorial...
I looked in < http://en.wikibooks.org/wiki/Eac3to/How_to_Use > but is to complicated and intimidating for me...
I don't succeed in getting the right icon to use it for encodings....
Maybe this night someone will give me some helpfull advices...
Thanks !!!
Hi i just did a post for ripping a movie and it has information for your problem in it
you can do that easily with MediaCoder
check it out if you didn't find your answer yet
http://forum.videohelp.com/threads/3...05#post2110105
Whoops, didn't realize this was a resurrected thread.
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 08:06 -
How to convert a .dts file to a dts encoded .wav for burning to DTS CD
By captain_tinker in forum AudioReplies: 3Last Post: 15th Feb 2007, 11:22 -
AC3 Filter using SPDIF. No AC3 or DTS in WMP or MCE
By amadeus00 in forum AudioReplies: 2Last Post: 11th Dec 2006, 04:03 -
Can a DTS movie be encoded to MP4?
By reverse in forum ffmpegX general discussionReplies: 5Last Post: 4th Jan 2005, 10:09 -
Can you copy a DTS encoded DVD to multiple CDs?
By operaghost in forum DVD RippingReplies: 0Last Post: 13th Jan 2002, 09:25
