    Hi there,
    I have EasyCAP DC60 (Syntek 1150 USB) installed with ULEADVideoStudio SE DVD.
    I have a video recorder connected with a scart with S-Video and RCA Phono connectors connected to EasyCAP DC60.
    Problem is that I keep getting horizontal grey lines on the capture screen.
    My operating System is Windows Vista Home Premium SP2
    I would very much appreciate that if someone who had this problem and solved it, please send us a link at to what I need to do
    Regards,
    DTreacy
    In UleadVideoStudio click Options>Video and Audio Capture Property Settings... and make sure to select "Video S-video" under "Video Input Source"
    I had the same problem & found the best way to run this system is to plug in your Easycap adapter (with the green power light ON) before turning on the computer, to get the power light on just turn on your VCR or Camcorder. This software is not very user friendly at all & the user manual is not much help,tells you how to edit etc but not how to get started in the first place. Hope this helps, there is also a video on Youtube (just type in syntek 1150) which is useful.
  1. EasyCap DC60 help!
    By FallenAngelII in forum Capturing
    Last Post: 8th Feb 2010, 15:56
  2. Easycap Capture, USB 2.0
    By Kimmytattoo in forum Capturing
    Last Post: 16th Jan 2010, 15:13
  3. Easycap DC60+?
    By wadeblfc in forum Capturing
    Last Post: 9th Jan 2010, 02:35
  4. Capturing Pal60 With Easycap DC60
    By e0turnerl in forum Capturing
    Last Post: 21st Mar 2009, 12:07
  5. EasyCap capture card
    By VirTu3 in forum Capturing
    Last Post: 5th Dec 2008, 18:56
About   Advertise   Forum   RSS Feeds   Statistics   Tools
