Can I enable 40MHz channel width for 2.4GHz on my wireless adapter and not affect 802.11g devices in a major way such as game consoles or other PCs?
"40 MHz channels is another feature incorporated into 802.11n which doubles the channel width from 20 MHz in previous 802.11 PHYs to transmit data. This allows for a doubling of the PHY data rate over a single 20 MHz channel. It can be enabled in the 5 GHz mode, or within the 2.4 GHz if there is knowledge that it will not interfere with any other 802.11 or non-802.11 (such as Bluetooth) system using those same frequencies."
Results 1 to 1 of 1
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
Need best router for multiple pc's....2.4ghz or 5.0ghz?
By neworldman in forum ComputerReplies: 5Last Post: 22nd Nov 2010, 10:36 -
802.11N vs 802.11G
By jyeh74 in forum ComputerReplies: 14Last Post: 18th Sep 2009, 19:39 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27 -
Recommend AGP 4x capture card for P4 2.4GHz computer please??
By w@ntonsoup in forum CapturingReplies: 16Last Post: 9th Oct 2007, 11:05
