Hello,
I am using the new version of Ripbot the 64bit version with Windows 7.
My problem with this is that this version is not giving me equal time settings when copying a blu-ray disc. The time frame is either off by 1 or too 100 seconds. Causing the copy to be off sync. This has happened with quite a few movies so far. Out of 6 movies two of them I was able to get done right. The rest have the settings way off. They were ripped to HDD by using AnyDvd HD paid full version. On the HDD the play perfect. But after going thru Ripbot its off sync. The old version of ripbot had the option to select stretch to equal out the time but this version does not have that. Can anyone assist with this issue? Thank you.
Thread: New Ripbot264 64bit
Why not use the old version? or does it not work at all for you?
Actually I have a post already in here ...."Sync Issues"
In that post I mentioned using Ripbot the older one) and BD-Rebuilder. There is where the off sync issues started from. So I thought to go to the 64bit version of ripbot with Win7. Now I cant change any of the time duration settings.
Lame MP3 on Virtualdub 64bit (win7 64bit)
By EdoScario90 in forum AudioReplies: 4Last Post: 7th Feb 2012, 09:36 -
move to 64bit windows
By beavereater in forum ComputerReplies: 31Last Post: 27th Oct 2011, 23:39 -
[Guide] Using DMFS on Windows7 64bit (with Sony Vegas Pro 10 64bit)
By Luponius in forum User guidesReplies: 8Last Post: 8th Oct 2011, 12:16 -
VirtualDub 64bit ?
By blewyn in forum Video ConversionReplies: 2Last Post: 15th Nov 2010, 23:01 -
Xvid for 64bit XP
By SerbianBoss in forum Video ConversionReplies: 1Last Post: 12th Jan 2008, 06:09
Statistics
Newest guides
Latest tool updates
New media comments
