  1. Hi everyone
    I've been looking at the forum and the FAQ and I'm pretty happy with what I would need to do hardware wise with building a HTPC but one thing I'm really looking for is to be able to record (at least) two freeview channels at once.
    It used to be easy, I'm sure some PVRs used to have dual tuners on them and a DVD-RW to back the recordings up but that is scarce now.
    So what I really need is a PC that will switch on automatically at the right time, record whatever I want it to (on two channels at once if needed...or four channels if I have two tuner cards (can you do that?) ) and then go back into standby until it's needed again.
    Could anyone recommend specialist software I would need to do this?
    Also could anyone recommend specialist twin capture cards so I can record two channels at once.
    If possible I would like to put two capture cards in there so I can record up to four channels at once, would specialist software recognise and support quad tuners?
    I am comfortable with building my own PCs but this is completely new to me!
    Many thanks
    My HTPC can PVR, but I don't. I use a DVD recorder with HDD for recording.
  3. Member edDV's Avatar
    Originally Posted by The Big Cheese
    Hi everyone
    Many thanks
    Most popular PVR software include
    - MCE (Vista and Win7)
    - SAGE-TV
    - BeyondTV
    - GBPVR (free)
    - MythTV (Linux and free)
    Expect a fairly steep learning/debug experience.
    Most supported tuner cards are Hauppauge PVR/HVR and ATI 550/650. Each site lists cards and issues.
    Quad support would be limited to specific model combos. Check each site for info.
    HD ATSC/DVB adds another layer of fun.
    http://www.kiva.org/about
    I am using DVBViewer for the recording purpose. It hi bernates after a completed recording and wakes up automatically before next recording. This is dobe with help of DVBViewer Task Scheduler plugin.
    I am now also building a Linux PVR, using VDR.
    This solution seems to be able to do what you want, but it is tricky to setup... It is more like a project to learn Linux for me.
    Both DVBViewer and VDR can handle muliple capture cards. I really can recommend DVBViewer as it is the most stable DVB recording software I have been used.
    I can only agree with ronnylov. DVBViewer is the very best software for DVB reception and recording.
  1. Bedroom HTPC build
    By rallynavvie in forum Computer
    Last Post: 5th May 2009, 08:22
  2. CHeaper to build HTPC than buy Hi-Def. DVD player?
    By ryangarfield in forum Media Center PC / MediaCenters
    Last Post: 18th Jan 2008, 15:24
  3. Please critique my proposed HTPC build
    By wazakenn in forum Media Center PC / MediaCenters
    Last Post: 22nd Sep 2007, 23:09
  4. Need HTPC recommend -first HTPC build
    By joshcali in forum Media Center PC / MediaCenters
    Last Post: 29th Sep 2006, 14:32
  5. Please help me to build my first HTPC!
    By cornelius in forum Computer
    Last Post: 3rd Oct 2004, 11:19
About   Advertise   Forum   RSS Feeds   Statistics   Tools
