hi all... i am having trouble figuring out a list of devices that will play High Definition 1080p Media Player over the network...
hook up to tv and lan then access the videos and stuff on computer and or internet...
so far found the following:
http://www.caloptic.com/store/index....products_id=42
http://www.newegg.com/Product/Produc...82E16882591001
http://www.caloptic.com/store/index....roducts_id=352
http://www.caloptic.com/store/index....products_id=20
but not i see have gigabit...
i guess what i am hoping is a single place that lists the possible products without having to do alot of searching...
any ideas
thanks
Results 1 to 10 of 10
Did you say you do have a gigabit LAN?Originally Posted by crazydrveRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
WDTV Live, ~US$120, 10/100 Ethernet, can use external USB drive.
http://www.newegg.com/Product/Produc...82E16822136472
yes i do have a gigabit lan... and i dont know if it would really matter but i would feel better having a gigabit device...
right now i am trying to price together a cheap htpc that i would use instead... it would only need to play the stuff not convert or encode, etc.
Here's one that I use:
SageTV HD Theater
Works with or without Sage TV Media Center. Works flawlessly on my 100MB LAN. It also has a wireless adapter. Gigabit is seriously not a requirement.
-drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
I'd second the WDTV Live as an Ethernet connected player. There are others like RoKu or the PS3 or XBox360.
Then there is the whole world of Windows MCE media extenders (incl. XBox360).
Does your TV support DNLA? Also read up on UPnP.
All this is early tech that will eventually converge into the TV or an attached player. Whatever you buy today will rapidly go obsolete.Recommends: Kiva.org - Loans that change lives.
Windows/Linux/Mac PC + Boxee
thanks for the suggestions all.. but i think i will just build a cheap computer unless someone has an idea against that...
computer is flexible and upgradebable... plus using windows media center u can set it up for non computer people with remote...
For playback Boxee is much more flexible than WMC. Still a bit buggy though.
yea i will be trying boxee and xbmc but right now i am running windows media center with windows 7 x64 and have had no problems...
i have tried blue ray and mkv files. plus netflix works in WMC
i am trying to keep it to one easy interface for my mom.... that way i can just give her whatever movies, tv, etc she wants and wont have to deal with dvd players, etc.
thanks for all the suggestions
Need info on DVD with windows media High Definition
By turboman in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2006, 13:53 -
hugh? toshiba high definition player for 73 pounds
By slimpickins in forum Newbie / General discussionsReplies: 2Last Post: 25th Mar 2006, 19:41 -
JVC UNVEILS AFFORDABLE pro HIGH DEFINITION DVD player
By BJ_M in forum Latest Video NewsReplies: 3Last Post: 30th Jun 2005, 15:28 -
Broadcom Announces First High Definition DVD Player/Recorder
By BJ_M in forum Latest Video NewsReplies: 2Last Post: 26th Jan 2005, 20:17 -
Convert High Definition Windows Media Video into DVD
By vioxx in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2004, 10:44
