Results 1 to 17 of 17
    I'm having trouble connecting my desktop computer to the TV.
    I got an "UltiMate 2000 AX" PC to TV converter, which converts VGA to inputs that you can put into the TV (S video, composite, etc). But whenever I plug it in, the image just scrolls vertically really fast in an endless fashion (you know what I mean), not to mention it is black and white. It does this on all computers and all TVs and I don't really know how to get it to work, considering it didn't come with any instructions. Talk about a waste of 40 bucks...
    Anyway, I also have a (male) S-video to composite converter, but my desktop doesn't have a port for S video like my laptops do. What should I do? Are there USB devices that can let your computer rout out video to S video ? Or would I have to get a new graphics card?
  2. Man of Steel freebird73717's Avatar
    That's what I would do. Much easier, more stable, and I can pretty much guarantee you better video quality than any vga to svideo converter you will find.
    Donadagohvi (Cherokee for "Until we meet again")
    My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
    So I can get a PCI graphics card that has an S video out function?? If so, then I'd be able to connect the desktop to the TV.
  4. Man of Steel freebird73717's Avatar
    Yes. Look Here
    You would also need to get a cord to run the sound from your soundcard to your tv's RCA sound composite in.
    Nstc = switch 1 down, switch 2 up ... for pal both are down ... once set, then connect to tv.
    Review... might give you a better idea
    Oh man, genius! I didn't even look at those switches...PAL is what I wanted, but the quality isn't terribly great. The image is a little shaky during movies, a little blinky. Is that to be expected with VGA to RCA? I noticed freebird said that the quality isn't always the best. I have it on 800 * 600 resolution.
  7. Man of Steel freebird73717's Avatar
    Okay if you are in Indianapolis why are you wanting PAL? You should need NTSC.
  8. Member edDV's Avatar
    Why do you want PAL? Do you have a PAL TV?
    Did you try NTSC?
    http://www.kiva.org/about
    This is true, D'OH. Thanks for the reminder. I switched it to NTSC. The blinkiness is still there, but it's not really noticeable if the video is actually playing and the frames are moving enough to distract from it.
    That being said, if I invested in a video card that had S video out, would it be better than this VGA translation? Like, crisper, and more stable??
  10. Member edDV's Avatar
    Should be better but not ideal.
    What kind of TV do you have?
    May I suggest you consider a Philips 5990/92 DVD player (capable of playing video from a USB flash or hard drive)?
    Or a Westen Digital Media player?
    Pretty standard Toshiba MW27F51, here's a specs page:
    http://www.tacp.toshiba.com/dvd/prod...?model=MW27F51
    Also, the converter came with some controls. H scale, V scale, brightness, contrast, hue, saturation, flick, sharpness, and OSD background. I'm not sure if any of those would deal with the subtle blinking...maybe flick?
  13. Member edDV's Avatar
    You will get better video quality off the suggested players.
    S-Video off a display card isn't pure interlace. It gets converted first to progressive 800x600 then is D/A converted and re-interlaced to 480i.
    Your converter is doing similar off a VGA input but using lower quality components.
    Also, looking at the specs for your TV on the link you provided, it doesn't mention your TV having S-Video input, only RCA video in (yellow jack, composite)
    Flick is probably a deflicker filter. That is what you want to look at. Interlaced video is inherently flickery whenever there are sharp, high contrast, horizontal edges in the frame. Deflicker filters work by blurring those edges. So you get less flicker at the cost of a blurrier picture.
    Nope ... that flicker is actual from those devices ... painful it is, lol ... mine causes the pc screen to flicker thou ... tv out put is fine ... I put it in the dodgy items box
    Yes, a gpu with tv out is going to be superior ... just double check the tv out option cable supplied is for component if tv only supports this type of extra input ... and not mini-din.
  17. Member edDV's Avatar
    Most display cards have a "flicker" filter in the S-Video out menus. This just frame averages stopping desktop flicker but causes motion lag and blur. You would use this for document display on a normal TV.
    S-Video can be converted to composite with a simple Y+C summing adapter. These usually come with the card.
  1. Connecting computer to TV
    By videohalp in forum Computer
    Last Post: 7th Apr 2009, 21:53
  2. Replies: 16
    Last Post: 14th Aug 2007, 13:13
  3. Problem connecting VCR to computer
    By unicorn in forum Newbie / General discussions
    Last Post: 7th May 2007, 00:18
  4. Connecting my computer to my TV
    By Vex in forum Computer
    Last Post: 1st Nov 2006, 13:50
  5. Connecting a Computer to the TV - Wireless
    By 808smokey in forum Computer
    Last Post: 20th Oct 2004, 04:47
About   Advertise   Forum   RSS Feeds   Statistics   Tools
