Turn a lcd monitor into a tv (Without Using PC) Any other options then Geting one of these Tv Tuner Box Thanks
If it didn't say "discontinued" I'd suspect a scamOriginally Posted by canadateck
A computer monitor is nowhere close to a TV. It lacks half the parts.
What is your source?
off air?
cable?
sat?
VCR?
DVD?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Maybe one of these two external tuners, but likely only a 720p picture using a LCD PC monitor instead of a TV.
http://www.newegg.com/Product/Produc...82E16815260022
http://www.newegg.com/Product/Produc...82E16815260027
They are more for a TV that lacks an ATSC/QAM tuner, but might work to that limited extent. Also, read the reviews. They may have a short life.
[Edit] These are newer TVBox models from the same company.
Cable.
There is other models I can buy at Tigerdirect or the Source. Just used that link for an example.
For a computer monitor, the tuner will need a VGA or DVI-D output. Computer monitors can't handle interlace.
The tuner box needs to deinterlace or inverse telecine.Recommends: Kiva.org - Loans that change lives.
Samsung LCD TV 32" fullHD won't turn on
By dzsoul in forum DVB / HDTVReplies: 38Last Post: 16th Apr 2012, 14:12 -
Pandora App on VIZIO LCD TV doesn't turn off when switched back to TV?
By jpersonette in forum Newbie / General discussionsReplies: 2Last Post: 15th Jan 2012, 17:16 -
Intensity Pro - no picture on monitor when I turn PC or PS3 on
By swillw in forum CapturingReplies: 3Last Post: 16th Feb 2010, 23:56 -
LCD TV vs. LCD Monitor for PC gaming
By Xenos80 in forum ComputerReplies: 6Last Post: 12th Feb 2009, 23:01 -
Displaying Photos on an LCD Monitor or LCD TV
By jbsiegel in forum DVB / HDTVReplies: 3Last Post: 25th Sep 2007, 12:29
