Hi,
I have seen various discussions where people ask how to convert stuff to the old mpeg-1 format, but the answer is always "why" or "just don't bother", so I'll explain my reasons briefly first...
I have just bought a Sony Bravia which has a USB port which understands how to play mpeg-1 files. It doesn't understand how to play layer 2 or divx etc. I would like to be able to convert some 1080 "HD" WMV, DivX and AVI files to Mpeg-1 so I can play them via a USB stick.
Is there a way of converting such files to a HD quality mpeg-1 file using ffmpeg? I have a Max OSX with the latest version of ffmpeg installed, but can't seem to get the best settings (I'm using the command line version, not ffmpegX). I also have the full Quicktime Pro HD edition installed, but it doesn't seem to create true layer 1 files, well they don't play on the tv...
Any ideas appreciated.
Cheers
Steve
Thread: avi -> mpeg1 in high quality
This doesn't sound right. A current Bravia should be able to read other than MPeg1.
An HD resolution MPeg1 file would be huge.
What is your TV model number?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
It's a 32" V5500 (KDL-32V5500U to be precise). The manual says Mpeg-1, but if it plays other than that it would be good - mpeg 2 for example, but I don't seem to have a sample file in that format which works...
Thanks for the quick reply btw
It should be able to play MPEG 2 video because it has a digital terrestrial tuner (MPEG 2 broadcast).
I managed to convert a wmv file into a mpeg2 file and yes, it works
This means that the manual that comes with the tv is incorrect!
Here are the switches I passed:
-vcodec mpeg2video -sameq -s 1280x720
1280x718 is what ffmpeg said the original video resolution was, but could anyone tell me are these optimum settings? Is what I am viewing after the job is done the best that is possible, or are there more optimum switches to pass?
Cheers
Steve
Nothing unusual there!Originally Posted by steve1401
Convert AVI from FLV to High Quality AVI
By Zhuge Liang in forum Video ConversionReplies: 6Last Post: 13th Jan 2007, 03:23 -
High Quality AVI?
By teamdork in forum Video ConversionReplies: 1Last Post: 15th Apr 2006, 22:13 -
mpeg2 to really really really high quality mpeg1: possible??
By trainspotter01 in forum Video ConversionReplies: 15Last Post: 23rd Mar 2003, 01:51 -
=>Normal quality+High Bitrate (Tmpgenc) = High Quality VC
By PainImposingFool in forum Newbie / General discussionsReplies: 4Last Post: 30th Oct 2002, 08:09 -
High pitch noise in AVI to MPEG1 with TMPGEnc
By samyboy in forum Video ConversionReplies: 10Last Post: 23rd Sep 2001, 00:57
