VideoHelp.com Forum
    some recent software programs that I installed anydvd(now uninstalled) nero 9(now uninstalled), dvdfab6
    It will burn ok but the disc it burns is seen as a cdrom and when I click on it to open it it says to insert a disc.
    If I put it in my other dvd drive it reads flawlessly
    I had another extrenal burner which did the same thing so I bought this one hoping that it wouldn't have the same problem
    Try uninstalling the DVD_ROM drive from device manager located in the control panel and restart the computer, it should automatically see the drive and reinstall it.
    I tried it and rebooted,did not work
    What OS are you using, XP or Vista? start ->Run->sfc /scannow. Do you have Roxio installed? If you reinstall Nero does it correct the problem? Its very possible that when you uninstalled Nero it removed some form of file association. Having Roxio and Nero is known to cause a few conflicts such as dvds being recognised as cds and such.
  5. DVD Ninja budz's Avatar
    use nero cleaner to make sure you've removed all the files or use regedit to remove files if you know how to use that.
    would be helpful if you posted the model of your dvd burner. also post your computer specs as well in your profile.
    newer dvd burners need to use a 80 wire ide cable or the drive won't work correctly.
  1. DVD on USB flash drive
    By jjis in forum Newbie / General discussions
    Last Post: 29th Jun 2011, 23:34
  2. Replies: 8
    Last Post: 30th Nov 2010, 16:03
  3. Windows XP sees external dvd burner as cd-drive
    By siskiou in forum DVD & Blu-ray Writers
    Last Post: 18th May 2010, 11:50
  4. Replies: 8
    Last Post: 28th Jan 2010, 13:00
  5. Using 500GB usb drive as player on Standalone with USB
    By OdubruS in forum DVD & Blu-ray Players
    Last Post: 26th Jul 2007, 05:36
