VideoHelp.com Forum
Results 1 to 12 of 12
    I have a DVD folder on the hard drive, didn't rip by myself. I am using AutoMKV to convert to x264.
    When having VTS_01_1.VOB as input this happens:
    19:50:15 0.98.4  - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - -
    19:50:15 Selected Input file:     O:\Ray Charles\VTS_01_1.VOB
    19:50:15 Selected Output dir:     D:\temp\
    19:50:15 Selected Final Name:     VTS_01_1
    19:50:15 Selected Container type: MKV
    19:50:15 Selected Encoder:        X264
    19:50:15 Selected Size:           Unlimited File Size
    19:50:15 Selected Profile:        Constant_Quality_CQ_Optimized.xml
    19:50:15 Selected Resizer:        NONE / Original
    19:50:15 Selected Filters:        RemoveGrain(mode=2)
    19:50:15 Selected Deinterlacer:   Safe
    19:50:15 Selected Field Order:    AUTO
    19:50:15 Manual Crop              Enabled
    19:50:15 Left Crop:               6
    19:50:15 Top Crop:                2
    19:50:15 Right Crop:              4
    19:50:15 Botton Crop:             2
    19:50:15 NeroAACEnc.exe:          not present
    19:50:15 Enabled Constant Quality With Unlimited Size (Q 20)
    19:50:15 Activate PGC Ripping:    1
    19:50:15 Track Language 1:        80: AC3 2/0 224
    19:50:15 Audio Codec 1:           Copy Original
    19:50:15 Track Language 2:        NONE
    19:50:15 Audio Codec 2:           Coding Tech. AAC
    19:50:15 Activate Anamorphic Encoding
    19:50:15 Selected Unlimited media size
    19:50:15 Dgindex CMD:             C:\Users\nes\Desktop\AutoMKV0984\exe\dgindex\dgindex.exe -FO=0 -OM=1 -TN=80 -YR=2 -AIF=[O:\Ray Charles\VTS_01_1.VOB] -OF=[D:\temp\movie] -exit -minimize
    19:52:05 D2V file size:           699688 bytes
    19:52:05 Audio 1:                 movie t80 2_0ch 224kbps delay 0ms.ac3
    19:52:05 Pre Audio 1' Size:       138570880 bytes
    19:52:05 Renamed file movie t80 2_0ch 224kbps delay 0ms.ac3 to movie t80 2_0ch 224kbps delay 0ms_.ac3
    19:52:05 Encoded 1' Audio Track:  movie t80 2_0ch 224kbps delay 0ms_.ac3 138570880 bytes
    19:52:06 Number of Frames:        148321
    19:52:06 Framerate:               29.970030
    19:52:06 Movie length in Seconds: 4949
    19:52:06 Movie Width/Height:      720/480
    19:52:06 DgIndex AR:              4:3
    19:54:07 Source is declared tff by a margin of 183/25.
    19:54:07 Advanced Deinterlace Routines Log
    19:54:07 Analyzed 887 sections of five frames
    19:54:07 Found Interlace Sections:  611 68.88%
    19:54:07 Found Progressive Sections:188 21.20%
    19:54:07 Found Telecined Sections:  88 9.92%
    19:54:07 Found Zero  Mov:  21.20%         188
    19:54:07 Found One   Mov:  4.74%         42
    19:54:07 Found Two   Mov:  9.92%         88
    19:54:07 Found Three Mov:  11.95%         106
    19:54:07 Found Four  Mov:  6.20%         55
    19:54:07 Found Five  Mov:  46.00%         408
    19:54:07 The Movie is declared to interlaced
    19:54:07 Starting  X264
    19:54:07 CRF encoding X264:       C:\Users\nes\Desktop\AutoMKV0984\exe\encoder\x264.exe --pass 1 --crf 20 --stats "D:\temp\.stats" --progress --keyint 250 --bframes 3 --qpmin 10 --qpmax 51 --no-psnr --trellis 1 --ref 3 --filter -1,-1 --subme 9 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me hex --no-ssim --level 4.0 --weightb --b-adapt 2 --b-pyramid --no-chroma-me --8x8dct --threads auto --thread-input --aq-mode 1 --aq-strength 1 --psy-rd 1.1:0.0  --sar 2726400:3084480  --output "D:\temp\movie.264" "D:\temp\movie.avs"
    19:54:08 X264 Final CRF Encoding Stats:
    19:54:08 Accepted values are between 697303040 and 741343232 bytes (movie+audio)
    19:54:08 Got a file of size: 0 bytes + audio size 138570880 bytes (138570880)
    19:54:08 Only Movie Size:         0 bytes
    19:54:08 BREAK ! FILE NOT SUPPORTED ! LAST TRY WITH FFMPEG!
    19:54:08 Switched to FFmpeg for Video Encoding!
    19:54:08 FFmpeg.exe String: "C:\Users\nes\Desktop\AutoMKV0984\exe\BeSweet\ffmpeg.exe" -an -threads 2 -i "O:\Ray Charles\VTS_01_1.VOB" -vcodec libx264 -bf 3 -qscale 19  -s 720x480  -deinterlace  -an -directpred 2 -refs 2 -r 29.970 -y "D:\temp\movie.mp4"
    19:55:39 Fished FFmpeg Encoding!
    19:55:39 "C:\Users\nes\Desktop\AutoMKV0984\exe\matroska\mkvmerge.exe" -o "D:\temp\VTS_01_1.mkv" --default-duration 0:30000/1001fps  --track-name -1:"VTS_01_1" --aspect-ratio -1:1.500000 "D:\temp\movie.264" --language -1:und --default-track -1:yes "D:\temp\movie t80 2_0ch 224kbps delay 0ms_.ac3"  --title "Done with AutoMKV 0.98.4 http://forum.doom9.org/showthread.php?t=140178 "
    19:55:41 Final Muxed size:        158477984 bytes
    19:55:41 Encoding finished:       00:01:34 elapsed time
    19:55:41 -----------------------------------------------------------------------
    19:55:41 Script AutoCrop.log
    19:55:41
    19:55:41 Crop(8,0,708,480)
    19:55:41 Script movie.avs
    19:55:41
    19:55:41 #loadpluginstart
    19:55:41
    19:55:41 #test1
    19:55:41
    19:55:41 #importstart
    19:55:41
    19:55:41 #test2
    19:55:41
    19:55:41 movie = mpeg2source("D:\temp\movie.d2v")
    19:55:41 function getOrder(clip c) {
    19:55:41 order = GetParity(c) ? 1 : 0
    19:55:41 Return order }
    19:55:41 #filter1start
    19:55:41
    19:55:41 #test3
    19:55:41
    19:55:41 movie = Tdeint(movie,order=1)
    19:55:41 last = movie
    19:55:41 crop(6,2,-4,-2)
    19:55:41 fixed_aspect = 1.491597
    19:55:41 out_width = 720
    19:55:41 #Aspect_Error = -0.560%
    19:55:41 out_height = 480
    19:55:41 #resizestart
    19:55:41
    19:55:41 #test4
    19:55:41
    19:55:41 #filter2start
    19:55:41
    19:55:41 #test5
    19:55:41
    19:55:41 RemoveGrain(mode=2)
    19:55:41 Script mkvmaudio.avs
    19:55:41
    19:55:41 LoadPlugin("C:\Users\nes\Desktop\AutoMKV0984\exe\filter\NicAudio.dll")
    19:55:41 LoadPlugin("C:\Users\nes\Desktop\AutoMKV0984\exe\filter\SoundOut.dll")
    19:55:41 LoadPlugin("C:\Users\nes\Desktop\AutoMKV0984\exe\BeSweet\BassAudio.dll")
    19:55:41 LoadPlugin("C:\Users\nes\Desktop\AutoMKV0984\exe\filter\FFMS2.dll")
    19:55:41 NicAC3Source("D:\temp\movie t80 2_0ch 224kbps delay 0ms.ac3")
    19:55:41 #Applying STEREO downmixing routines
    19:55:41 function stereo(clip a)
    19:55:41 {
    19:55:41 flr = GetChannel(a, 1, 2)
    19:55:41 fcc = GetChannel(a, 3)
    19:55:41 lfe = GetChannel(a, 4)
    19:55:41 lfc = MixAudio(fcc, lfe, 0.2071, 0.2071)
    19:55:41 mix = MergeChannels(lfc, lfc)
    19:55:41 lrc = MixAudio(flr, mix, 0.2929, 1.0)
    19:55:41 blr = GetChannel(a, 5, 6)
    19:55:41 Return MixAudio(lrc, blr, 1.0, 0.2929)
    19:55:41 }
    19:55:41 #
    19:55:41 6==Audiochannels() ? stereo() : last
    19:55:41 function addvideo(clip c) {
    19:55:41 blankclip(length = Int(100 * AudioLengthF(c) / float(audiorate(c))), fps=100)
    19:55:41 Return audiodub(last,c)
    19:55:41 }
    19:55:41 Normalize()
    19:55:41
    19:55:41
    19:55:41 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - - - - - - -
    When instead selecting VTS_01_0.IFO I get this:
    20:00:37 0.98.4  - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - -
    20:00:37 Selected Input file:     O:\Ray Charles\VTS_01_0.IFO
    20:00:37 Selected Output dir:     D:\temp\
    20:00:37 Selected Final Name:     Ray Charles
    20:00:37 Selected Container type: MKV
    20:00:37 Selected Encoder:        X264
    20:00:37 Selected Size:           Unlimited File Size
    20:00:37 Selected Profile:        Constant_Quality_CQ_Optimized.xml
    20:00:37 Selected Resizer:        NONE / Original
    20:00:37 Selected Filters:        RemoveGrain(mode=2)
    20:00:37 Selected Deinterlacer:   Safe
    20:00:37 Selected Field Order:    AUTO
    20:00:37 Manual Crop              Enabled
    20:00:37 Left Crop:               6
    20:00:37 Top Crop:                2
    20:00:37 Right Crop:              4
    20:00:37 Botton Crop:             2
    20:00:37 NeroAACEnc.exe:          not present
    20:00:37 Enabled Constant Quality With Unlimited Size (Q 20)
    20:00:37 Activate PGC Ripping:    1
    20:00:37 Track Language 1:        80: English (AC3 2ch, 0xBD 0x80) [0]
    20:00:37 Audio Codec 1:           Copy Original
    20:00:37 Track Language 2:        NONE
    20:00:37 Audio Codec 2:           Coding Tech. AAC
    20:00:37 Activate Anamorphic Encoding
    20:00:37 Selected Unlimited media size
    20:00:37 Activate PGC processing: PGC 1 [1:22:24:01]
    20:00:37 Dgindex CMD:             C:\Users\nes\Desktop\AutoMKV0984\exe\dgindex\dgindex.exe -FO=0 -OM=1 -TN=80 -YR=2 -AIF=[O:\Ray Charles\VTS_01_1.vob] -OF=[D:\temp\movie] -exit -minimize
    20:02:54 D2V file size:           699688 bytes
    20:02:54 Audio 1:                 movie t80 2_0ch 224kbps delay 0ms.ac3
    20:02:54 Pre Audio 1' Size:       138570880 bytes
    20:02:54 Renamed file movie t80 2_0ch 224kbps delay 0ms.ac3 to movie t80 2_0ch 224kbps delay 0ms_.ac3
    20:02:54 Encoded 1' Audio Track:  movie t80 2_0ch 224kbps delay 0ms_.ac3 138570880 bytes
    20:02:55 Number of Frames:        148321
    20:02:55 Framerate:               29.970030
    20:02:55 Movie length in Seconds: 4949
    20:02:55 Movie Width/Height:      720/480
    20:02:55 DgIndex AR:              4:3
    20:05:00 Source is declared tff by a margin of 183/25.
    20:05:00 Advanced Deinterlace Routines Log
    20:05:00 Analyzed 887 sections of five frames
    20:05:00 Found Interlace Sections:  611 68.88%
    20:05:00 Found Progressive Sections:188 21.20%
    20:05:00 Found Telecined Sections:  88 9.92%
    20:05:00 Found Zero  Mov:  21.20%         188
    20:05:00 Found One   Mov:  4.74%         42
    20:05:00 Found Two   Mov:  9.92%         88
    20:05:00 Found Three Mov:  11.95%         106
    20:05:00 Found Four  Mov:  6.20%         55
    20:05:00 Found Five  Mov:  46.00%         408
    20:05:00 The Movie is declared to interlaced
    20:05:00 Starting  X264
    20:05:00 CRF encoding X264:       C:\Users\nes\Desktop\AutoMKV0984\exe\encoder\x264.exe --pass 1 --crf 20 --stats "D:\temp\.stats" --progress --keyint 250 --bframes 3 --qpmin 10 --qpmax 51 --no-psnr --trellis 1 --ref 3 --filter -1,-1 --subme 9 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me hex --no-ssim --level 4.0 --weightb --b-adapt 2 --b-pyramid --no-chroma-me --8x8dct --threads auto --thread-input --aq-mode 1 --aq-strength 1 --psy-rd 1.1:0.0  --sar 2726400:3084480  --output "D:\temp\movie.264" "D:\temp\movie.avs"
    20:05:01 X264 Final CRF Encoding Stats:
    20:05:01 Accepted values are between 697303040 and 741343232 bytes (movie+audio)
    20:05:01 Got a file of size: 0 bytes + audio size 138570880 bytes (138570880)
    20:05:01 Only Movie Size:         0 bytes
    20:05:02 "C:\Users\nes\Desktop\AutoMKV0984\exe\matroska\mkvmerge.exe" -o "D:\temp\Ray Charles.mkv" --default-duration 0:30000/1001fps  --track-name -1:"Ray Charles" --aspect-ratio -1:1.500000 --chapters "C:\Users\nes\Desktop\AutoMKV0984\exe\chapters.txt" "D:\temp\movie.264" --language -1:eng --default-track -1:yes "D:\temp\movie t80 2_0ch 224kbps delay 0ms_.ac3"  --title "Done with AutoMKV 0.98.4 http://forum.doom9.org/showthread.php?t=140178 "
    20:05:02 Final Muxed size:        -1 bytes
    20:05:02 Encoding finished:       00:00:02 elapsed time
    20:05:02 -----------------------------------------------------------------------
    20:05:02 Script AutoCrop.log
    20:05:02
    20:05:02 Crop(8,0,708,480)
    20:05:02 Script movie.avs
    20:05:02
    20:05:02 #loadpluginstart
    20:05:02
    20:05:02 #test1
    20:05:02
    20:05:02 #importstart
    20:05:02
    20:05:02 #test2
    20:05:02
    20:05:02 movie = mpeg2source("D:\temp\movie.d2v")
    20:05:02 function getOrder(clip c) {
    20:05:02 order = GetParity(c) ? 1 : 0
    20:05:02 Return order }
    20:05:02 #filter1start
    20:05:02
    20:05:02 #test3
    20:05:02
    20:05:02 movie = Tdeint(movie,order=1)
    20:05:02 last = movie
    20:05:02 crop(6,2,-4,-2)
    20:05:02 fixed_aspect = 1.491597
    20:05:02 out_width = 720
    20:05:02 #Aspect_Error = -0.560%
    20:05:02 out_height = 480
    20:05:02 #resizestart
    20:05:02
    20:05:02 #test4
    20:05:02
    20:05:02 #filter2start
    20:05:02
    20:05:02 #test5
    20:05:02
    20:05:02 RemoveGrain(mode=2)
    20:05:02 Script mkvmaudio.avs
    20:05:02
    20:05:02 LoadPlugin("C:\Users\nes\Desktop\AutoMKV0984\exe\filter\NicAudio.dll")
    20:05:02 LoadPlugin("C:\Users\nes\Desktop\AutoMKV0984\exe\filter\SoundOut.dll")
    20:05:02 LoadPlugin("C:\Users\nes\Desktop\AutoMKV0984\exe\BeSweet\BassAudio.dll")
    20:05:02 LoadPlugin("C:\Users\nes\Desktop\AutoMKV0984\exe\filter\FFMS2.dll")
    20:05:02 NicAC3Source("D:\temp\movie t80 2_0ch 224kbps delay 0ms.ac3")
    20:05:02 #Applying STEREO downmixing routines
    20:05:02 function stereo(clip a)
    20:05:02 {
    20:05:02 flr = GetChannel(a, 1, 2)
    20:05:02 fcc = GetChannel(a, 3)
    20:05:02 lfe = GetChannel(a, 4)
    20:05:02 lfc = MixAudio(fcc, lfe, 0.2071, 0.2071)
    20:05:02 mix = MergeChannels(lfc, lfc)
    20:05:02 lrc = MixAudio(flr, mix, 0.2929, 1.0)
    20:05:02 blr = GetChannel(a, 5, 6)
    20:05:02 Return MixAudio(lrc, blr, 1.0, 0.2929)
    20:05:02 }
    20:05:02 #
    20:05:02 6==Audiochannels() ? stereo() : last
    20:05:02 function addvideo(clip c) {
    20:05:02 blankclip(length = Int(100 * AudioLengthF(c) / float(audiorate(c))), fps=100)
    20:05:02 Return audiodub(last,c)
    20:05:02 }
    20:05:02 Normalize()
    20:05:02
    20:05:02
    20:05:02 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - - - - - - -
    I have reinstalled ffdshow and avisynth.
    Not the first time it happens, but now i really want to solve it!
    You said you didn't rip the dvd itself, if you open the vob file in Powerdvd, or such does the time counter say on zero while playing the file?
    Does it have to be Powerdvd? In mpchc the time counter works all right. I have also made an iso with imgburn and then reripped with dvd decrypter to see if it had anything to do with a encryption still present. No progress.
    The DVD you made, try making an mkv file using makemkv and see if it fails as well.
    That works but converting to x264 after that fails as before.
    try running the ripped dvd through dvd shrink.
    Not helping
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Try another converter like handbrake, staxrip, megui, xvid4psp. All can make h264 using x264.
    Trying Handbrake, it's encoding now. But ETA ~7 hours for 80 minutes video??
    Handbrake made a 11GB file :P Isn't 80% the same as 20 as Quantizer?
    Testing staxrip..
    Nope, staxrip gave me this after some encoding:
    Operation failed!
    x264 Encoder failed with exit code -1
    avis [info]: 704x464 @ 29.97 fps (148321 frames)
    x264 [info]: using SAR=10/11
    x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.1 Cache64
    x264 [info]: profile High, level 3.0
    StaxRip.ErrorAbortException: x264 Encoder failed with exit code -1
       at StaxRip.H264CmdlEncoder.Encode(String passName, String exe, String args, Boolean isErrorStream, String[] logValuesToSkip)
       at StaxRip.x264Encoder.Encode()
       at StaxRip.MainForm.Encode()
       at StaxRip.MainForm.RunJobs()
    What i need is a better source
  1. MKV file not supported on Cello 3D TV
    By sjpriest79 in forum Newbie / General discussions
    Last Post: 24th Nov 2011, 17:39
  2. Converting from flv to any file supported by quicktime
    By alanswartz in forum ffmpegX general discussion
    Last Post: 24th Feb 2008, 18:23
  3. AVI File Not Supported by TMPEGnc?
    By The Monkees in forum Video Conversion
    Last Post: 3rd Feb 2008, 18:26
  4. Is there a list of all supported files supported by svcd2dvd ?
    By geek2330 in forum SVCD2DVD & VOB2MPG
    Last Post: 19th Oct 2007, 11:07
  5. Replies: 13
    Last Post: 12th Oct 2007, 08:40
