Hey all,
Last weekend I recorded the World Touring Car championship on Eurosport HD but I have problem with it... When I open the raw TS file with DGAVCIndex, it works good but when I save the project in dga and open the .avs file in another software, here's what I see...![]()
Something is cleary wrong here... Is there a way to solve this (it worked fine before) or is there another software to open video from EurosportHD ? I want to convert the raw file to another format...
Thanks in advance.![]()
It's a common problem with certain h264 videos and DGAVCIndex
You can use dgavcdecnv instead, but you have to buy it ($15) That's the fastest way.
You can also try
Directshowsource("yourfile.mts")
in Avisynth"Quality is cool, but don't forget... Content is King!"
Thank you.
Will test it later.
You exceeded the motion speed limit vs. signal to noise. 8 bit video sucks but it is cheap.
http://www.kiva.org/about
Well I formated my computer and can't get it to work at all now.
Here's a sample video from Eurosport HD
http://www.racefr.com/temp/20100409_2052EUROSPORTHD.ts
What's wrong with my avs file ? When I open it with Virtualdub for example, I get an error. "avisynth open failure: directshowsource couldn't open as video or audio..."
loadplugin("C:\Program Files\AviSynth 2.5\plugins\DirectShowSource.dll")
directshowsource(" etc... \20100409_2052EUROSPORTHD.ts")
My .ts & .dll files are in the right folder for info. I use Avysynth 2.5.8.
Install haali media splitter and ffdshow for decoder (or divx h.264)
For win7 use preferred filter tweaker
Recoding AVC - MeGUI is using DGIndex instead of DGAVCIndex?
By SamYYZ in forum Video ConversionReplies: 0Last Post: 28th Apr 2009, 17:11 -
Problem with Sync' of Video & Audio after Demux & Mu
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 5th Jul 2004, 19:53 -
Problem with Divx 5.1.1 & Xvid Codecs wi
By aamir12345678 in forum Video ConversionReplies: 0Last Post: 30th Mar 2004, 22:33 -
DV & Premier Playback Problem
By eyemessiah in forum CapturingReplies: 0Last Post: 7th Feb 2004, 02:54 -
Panasonic user's what is 'DVD-VIDEO MODE&amp
By spiderman2k1 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 10th Jan 2004, 16:56
