I'm running ffmpegX on Snow Leopard and it run absolutely fine. The only problems I am having which I need help with, is that when I open the application it never finds the mpeg2enc and I have to locate it manually. If anyone knows a fix for this it would really help.
The second issue is with FLVTool2. I tried to use the terminal and followed the instructions to the letter and here is the result.
Open terminal.app
Type cd [drop the folder here] [press return key] no problem
Type ruby setup.rb config [press return key] -ruby: No such file or directory -- setup.rb (LoadError)
Type ruby setup.rb setup [press return key] also load error
Type sudo ruby setup.rb install [will require that you enter your login password] [press return key]
Does anyone know how to fix this?
Thank you in advance.
Results 1 to 18 of 18
Thread: ffmpegX and Snow Leopard
drasw
Did you put a space character after "cd "?Originally Posted by drasw
Did you drop the folder "flvtool2-1.0.6" onto the Terminal window?
Do you have ruby installed as part of the BSD subsystem? Type "ruby --version" in the Terminal to verify.
Do you see a file "setup.rb" in the folder "flvtool2-1.0.6"?
I did see the file set-up was I supposed to click on that?
I would say I don't have ruby installed in the BSD subsystem as I do not know what that is or how to do it. Any help would be great.
Thanksdrasw
No, don't click it. The Terminal commands will use it; the file just has to be there.Originally Posted by drasw
Ruby is a Unix command line scripting language. ffmpegX uses ruby to instruct flvtool2 what to do. Ruby is also used to install flvtool2. Under Mac OS 10.3/10.4/10.5, ruby is part of a standard install of the OS. Not sure about 10.6, as I don't run that yet.Originally Posted by drasw
If you enter in the Terminalthen it should return the version number (and a date) of the installed ruby. If there is no ruby, this should return an error message saying that there is no ruby. Please test this first.Code:ruby --version
Try this zipped copy of mpeg2enc. Unzip before locating it in ffmpegX. It worked for some users that had trouble with the official direct download.Originally Posted by drasw
I typed in the command you suggested and received this:
ruby 1.8.7 (2008-08-11 patchlevel 72) [universal-darwin10.0]drasw
The zipped copy of mpeg2enc. Worked like a charm. Now if we can get the FLVTool2 working we are home free.
Once the set-up is complete am I able to convert a video to a transparent flash video?
By the way, your knowledge is fantastic.drasw
Then ruby is installed on your system.Originally Posted by drasw
The problem has to be in the details of how you entered the commands when trying to install flvtool2.
I copied them exactly as they appear in the instructions.
Open terminal.app
Type sudo ruby setup.rb install [will require that you enter your login password] [press return key]drasw
Could you let me have a look at the content from the Terminal window, after trying? Can you copy that here?
After I type CD and drag the folder I get: [Process completed]
after ruby setup.rb config I get: -ruby: No such file or directory -- setup.rb (LoadError)
[Process completed]
after ruby setup.rb setup I get -ruby: No such file or directory -- setup.rb (LoadError)
[Process completed]
after sudo ruby setup.rb install I get Password:drasw
By the way, am I supposed to check the box that says run command in a shell?
drasw
As far as I know, the Terminal is case-sensitive, which makes "cd" a valid command for changing the working directory, but it makes "CD" an unknown command. Typo?Originally Posted by drasw
The many occurrences of "[Process completed]" signifies a logout after each command, which is not how these commands are intended. It explains the "No such file or directory" errors as if the previous command was 'forgotten', or like not in the same shell.Originally Posted by drasw
When referring to 'Terminal', the Terminal shell window is meant, as that is the only interface upto 10.5. So, yes, it sounds logical to me, ... but where do you find such a checkbox? I can't find it on my system... Is that a 10.6 thing? Now we're getting somewhereOriginally Posted by drasw
I did not use the CD but rather the cd and the first step always works.
Are you saying that after I type in the command, that the little box that opens is supposed to not be closed? and then I should enter the next line in a new command line , then leave that one opened, and so on?
Lastly, on 10.6 Leopard there is that little box to check.drasw
I think I am getting somewhere now. When they ask me for my password, is it the password I use to log in to my computer, or is it a FFMPEGX specific password?
drasw
I think I may have it. How do I test to know that it is correct?
drasw
I figured that out based on your previous message. Now I just need to know how I test to make sure I did it correctly?
Then one last thing if you know. How do I use this software to convert to a transparent flash video.
You are so fantastic. This forum needs to give you super start status because that is what you are.drasw
10.6 Snow Leopard compatibility
By 303 in forum ffmpegX general discussionReplies: 5Last Post: 15th Nov 2009, 10:10 -
Garbled audio playback in snow leopard
By several in forum MacReplies: 3Last Post: 5th Nov 2009, 10:06 -
Snow Leopard and Toast/MTR/MyDVDEdit/MPEGStreamclip
By danielmak in forum MacReplies: 13Last Post: 10th Oct 2009, 14:02 -
ffmpegx/snow leopard applescript problem
By jape in forum ffmpegX general discussionReplies: 1Last Post: 22nd Sep 2009, 12:00
