VideoHelp.com Forum
    I have Samsung DVD-1080P9 with a Region code 1 and I have tons of DVD`s from europe witch I can not play on this player..Is there any remedy for this player to become Region free ?...
  2. Member hech54's Avatar
    Once again.
    Changing the Region Code does not guarantee you will be able to watch "European" DVDs because European DVDs are PAL Format. America is NTSC format. Video Format and Region Codes have nothing to do with each other.
    It will play..Before, I have Philips Dvd player and after I change the region all " european" DVD`s have played , so if I find the way to change the region on this one they will also play...
    The fact that "it worked in the past on model X" does NOT mean "it will work today on model Y". If you can find a hack for your player AND your player is able to convert PAL video to NTSC output, then yes, you can watch those movies. However, you should be aware that the vast majority of Samsung DVD players today are region locked and cannot be made region free. If you aren't able to find a hack for your player it's because one does not exist.
    Turn ON the DVD player.
    Press FORWARD button on the DVD unit itself (not the remote control) until the RESET menu appears.
    Select language, 1 = English (using the remote control - press the 1 button).
    The press REPEAT on the remote control (NOTE: use the REMOTE key at the bottom of the remote control - ignore the one market Remote in the number buttons - it won't work) and key in the Region 4 password = 7 6 8 8 4 using the remote control.
    A number "4" will show on the top left hand corner of the screen.
    Then press 9 on the remote control to make the DVD player Multi Region (a number 9 will display in place of the 4).
    Exit the menu and restart the DVD player.
    Simple as that.
  1. Samsung DVD 1080P9 + External HD
    By ih8winter in forum DVD & Blu-ray Players
    Last Post: 22nd Apr 2011, 16:58
  2. Made my Samsung dvd-1080P9 region free - but pic went b/w
    By pjotrrr in forum DVD & Blu-ray Players
    Last Post: 28th Aug 2009, 14:18
  3. samsung 1080p9 wanna play rmvb movies
    By phantomeduke in forum Video Conversion
    Last Post: 29th Jul 2009, 12:50
  4. Samsung 1080P9
    By jbond994 in forum DVD & Blu-ray Players
    Last Post: 24th May 2009, 04:17
  5. Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
    By MacPCConsultants in forum DVB / HDTV
    Last Post: 7th Jun 2008, 01:42
