    Years ago I bought the Nvidia personal cinema which included a transparent green tuner box which was connected to the PCI card via a propriotary control bus cable. I assume this cable is what supplies the tuner box with it's power. Does anyone know the pinout for this bus cable? I imagine there must be a way to mod this to function w/o the card. I would like to also mod the cable to have one end spliced with a male USB so it can interface that way...
    Is this possible or am I way off on this idea?
    Looking for anyone who may have explored this...
    Here are a couple pics of the tuner box in question:
    http://www.astradistribution.com/images/box.jpg
    http://www.www.xbitlabs.com/images/v...a/tv-tuner.jpg
    Thanks for any ideas...
    oh BTW, the reason I am looking into this, I no longer have my tower PC. I would like to see if this box can be used with my laptop (via USB) since it's sitting around before I plunk down the $$ on a new tuner box.
    Be who you are and say what you feel because those who mind don't matter and those who matter don't mind...
  2. Mod Neophyte Super Moderator redwudz's Avatar
    In the first JPEG, I only see video and audio output cables from the computer. No type of power cable. And I would doubt that a USB connection would supply enough power, especially from a laptop. USB is 5VDC, limited to 500ma. (1/2 Amp) The box may also run on 12VDC, also available in a computer. You would be better off to use a 'wall wart' DC power supply, but you would have to know the correct voltage and amperage the device needs.
    Then you would also need the software to control the tuner. All in all, this project could be very difficult without the proper cabling and software.
    One other problem if you plan to tune over-the-air TV broadcasts are that most all of them are digital now and I don't think that tuner will work with digital inputs. Lots of cable suppliers still use analog video, though.
    Something like this may be a better way to go: http://www.newegg.com/Product/Produc...-023-_-Product
  1. Inquiry - Kworld SA-290-Q LE TV Tuner Box
    By Frank-0-Video in forum Newbie / General discussions
    Last Post: 27th Jan 2009, 14:39
  2. Analog TV Tuner with Digital Cable Box???
    By bambamrl in forum DVB / HDTV
    Last Post: 17th Dec 2004, 22:20
  3. Connecting a TV Tuner card to PC with Cable box
    By bambamrl in forum Newbie / General discussions
    Last Post: 22nd Nov 2004, 21:33
  4. TV Tuner Box: PAL-M (Brazil) with Y/C Video Out
    By wilsonrio in forum Newbie / General discussions
    Last Post: 14th Oct 2004, 22:52
  5. Nvidia Video Card AGP + ATI PCI Tv card in same computer ?
    By mrtarzan in forum Newbie / General discussions
    Last Post: 6th Nov 2002, 20:36
About   Advertise   Forum   RSS Feeds   Statistics   Tools
