VideoHelp.com Forum
    Question, I have CS4, Pinnacle 14 and Vegas 9.
    When I edit in DV, I can edit, scrub and playback through the camcorder, thus use an external TV to see the video.
    In HDV, I can only see the video through the camcorder when I print to tape, thus all editing, scrubbing and previews must be done on the computer screen, not as good of an option as a TV set, plus I must re-render every time and start from the beginning. I cannot just select a scene and preview, it is all or nothing. The controls do not function when playing back HDV
    The camera is properly set to HD mode, and I have 4 cameras, it is the same with all of them.
    Can anyone bring me up to speed here? All setting are in order. Pinnacle support tells me that external playback option is not offered with HD editing. Is this the scoop?
    Many thanks! Tim
  2. Member edDV's Avatar
    For Vegas 9 Pro read these then discuss. I won't be able to test until this weekend. I'm in the middle of a job.
    http://www.internetvideomag.com/Arti...me_Preview.htm
    http://209.112.246.111/cgi-bin/displ...0028162439.htm
    http://forums.creativecow.net/readpost/24/873054
    http://www.kiva.org/about
    Thanks Ed, So it appears by more hardware is the solution? This one caught me by surprise. A real pain editing in HD.
  4. Member edDV's Avatar
    Vegas 9 pro also supports monitoring out the DVI-D display card output but this requires card driver and monitor calibration.
    The big boys edit uncompressed or with digital intermediates and monitor off SDI.
  1. Capturing HDV Tapes using a DV Camcorder
    By Raz1 in forum Capturing
    Last Post: 18th May 2011, 15:49
  2. Capturing/editing/ authoring from a Canon HDV HV 40 camcorder
    By avz10 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 29th Aug 2009, 00:23
  3. Sony HDV HC5 Camcorder and Firewire Cable
    By fjmr in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 7th Jul 2008, 05:38
  4. H264 (AVCHD) OR HDV Camcorder ?
    By Zetti in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 27th Dec 2007, 08:24
  5. Options for playing HDV video (other than through the camcorder)...
    By Sal C in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 1st Nov 2007, 17:19
