VideoHelp.com Forum
    I have over than 1000 files, which i grab from my dvd´s.....
    The files are in this format:
    P:\1012.mpg
       General
          Complete name : P:\BOTAR AQUI\1012.mpg
          Format : MPEG-PS
          File size : 2.89 GiB
          Duration : 42mn 45s
          Overall bit rate : 9 668 Kbps
       Video #224
          Format : MPEG Video
          Format version : Version 2
          Format profile : Main@Main
          Format settings, Matrix : Default
          Duration : 42mn 45s
          Bit rate mode : Constant
          Bit rate : 8 900 Kbps
          Nominal bit rate : 9 000 Kbps
          Width : 720 pixels
          Height : 480 pixels
          Display aspect ratio : 4:3
          Frame rate : 29.970 fps
          Standard : NTSC
          Colorimetry : 4:2:0
          Scan type : Interlaced
          Scan order : Top Field First
          Bits/(Pixel*Frame) : 0.859
          Stream size : 2.66 GiB (92%)
       Audio #128
          Format : AC-3
          Format/Info : Audio Coding 3
          Duration : 42mn 45s
          Bit rate : 384 Kbps
          Channel(s) : 2 channels
          Channel positions : L R
          Sampling rate : 48.0 KHz
          Video delay : -265ms
          Stream size : 117 MiB (4%)
    I have almost 1TB now, and my hd is almost full so
    I wish to convert all these files to a smaller sizes, with minimun of quality loss, i have another empty hd to convert these files...
    which program and format u think i have to use?
    thx in advanced
    sry my english
  2. Mod Neophyte Super Moderator redwudz's Avatar
    You might look into the H.264 codec. It's fairly compact and still has good quality in small filesize. Better than XviD/Divx, IMO. A couple of programs to look at: Handbrake, XviD4PSP.
    Or StaxRip or Megui and convert to h264 video with aac audio in a mp4 or mkv. Try different encoding profiles in the applications and you might have to checkout different deinterlacings filters.
    But encoding all those will take a long long time.
    thx for reply!!
    u know if these program have batch option?
    thx
  5. Member edDV's Avatar
    You do realize any conversion will be lossy?
    I'd save those MPeg2. Hard drives are cheap.
    http://www.kiva.org/about
  1. Replies: 4
    Last Post: 22nd Dec 2011, 17:29
  2. mpg image wrong 'size'
    By HMH in forum SVCD2DVD & VOB2MPG
    Last Post: 16th Sep 2010, 16:49
  3. Replies: 3
    Last Post: 20th Dec 2009, 09:19
  4. Standard quality/size for MPEG (*.mpg) videos?
    By Ashman01 in forum Video Conversion
    Last Post: 22nd Feb 2009, 18:55
  5. Mpg to fixed avi size.
    By jjulio1 in forum Video Conversion
    Last Post: 8th Mar 2008, 14:59
