    I'm looking for a all-in-one video converter that has the following 2 features:
    1. A preview window showing how the output file will look in terms of aspect ratio, crop, pad, etc. (Xmedia Recode has this)
    2. An option to select the output file size which would automatically adjust the bitrate accordingly.
    Xvid4psp will show the preview directly and you can set the output file size if you change the encoding mode to "2-pass size". You find the crop, pad, aspect ratio functions under Video->Resolution/Aspect. But it may be a bit buggy under some systems.
    Thanks, i'll definitely check that out..... What about for 1 pass encoding?
  4. Member usta's Avatar
    I think 1pass will show only an approximation of the output size.
    I just realized in Xmedia Recode, I can hightlight the video then choose "Options > Bitrate Calculator" then specify the output size and the bitrate will adjust. The few that I have done have came out larger than what I specify so it is just an estimate so I just specify a bit smaller size than what I really want. Thanks to all for the assistance.
  1. DTV Converter Features I want with it
    By lacywest in forum DVB / HDTV
    Last Post: 24th Jan 2009, 10:31
  2. Features
    By Jedi_Knight in forum SVCD2DVD & VOB2MPG
    Last Post: 29th May 2007, 19:29
  3. Which Has Better Features?
    By chole in forum DVD & Blu-ray Recorders
    Last Post: 6th Feb 2005, 00:43
  4. Features id like to see
    By kolobos in forum SVCD2DVD & VOB2MPG
    Last Post: 2nd Feb 2005, 20:02
  5. mpeg2 converter::premiere 6 native converter VS tmpgEnc
    By astroboy2520 in forum Newbie / General discussions
    Last Post: 11th Aug 2003, 02:02
About   Advertise   Forum   RSS Feeds   Statistics   Tools
