Hello Everyone:
I have a MPEG2 (converted from .AVI) video that needs a little "tweeking". I have decided to use ReStream to re-do the aspect ratio from 16:9 to cinama scope. It is already 16:9, but the screen in the resulting file looks a tab squeezed (sought of like 4:3 on steroids.![]()
(I am kind of embarrassed here) but I am not familiar with the tick buttons in the program:
Intra matrix
Non intra matrix
Picture Coding Extension
Group of Pictures
Sequence Extension
Stream Extras
Sequence Display Extension
I am, however, totally familiar with Resolution, Framerate, VBV Buffer Size, Bitrate
My question is do I need to tick any of these buttons if all I need to do is recode the aspect ratio?
Better yet, if you know of any site where they explain each of these attributes, that would suffice.
Your assistant would be highly appreciated.
Montgal_NYC
Thread: ReStream
can you post a screenshot of the video? use mpc, file->save image.
just change the aspect ratio to what you want and save it. It needs demuxed video (m2v)
should play with correct ar on your pc, standalone dvd players may get confused with any value other than 4:3 or16:9
If it's already 16:9, there's nothing more you can do. You can't use ReStream to change it to cinemascope. The proper cropping/resizing should already have been done before the video was sent to the encoder. If for DVD, you can't use the 2.21:1 DAR. How did you do the AVI2MPEG conversion? What program?Originally Posted by montgal
If all you're changing is the DAR, leave the rest alone. And you're not reencoding anything since ReStream isn't an encoder. It just changes flags in the video stream and writes out a new video for you.Originally Posted by montgal
Restream question
By Ennio in forum Newbie / General discussionsReplies: 0Last Post: 26th Oct 2007, 15:33 -
Restream guide
By dphirschler in forum Video ConversionReplies: 0Last Post: 2nd Aug 2006, 15:43 -
Restream in tools section....
By kenmo in forum Video ConversionReplies: 4Last Post: 9th Feb 2004, 11:02 -
Restream program
By MCD in forum Video ConversionReplies: 6Last Post: 16th Dec 2003, 10:45 -
Put the timecode to 0 with restream?
By atlas in forum Authoring (DVD)Replies: 12Last Post: 29th Oct 2003, 08:52
Statistics
Newest guides
Latest tool updates
New media comments
