VideoHelp.com Forum
    Hey,
    I have got a Blu-Ray (Speed) which Im trying to get working. The main audio is in .dts which wont play, instead the directors commentary plays which is in ac3.
    So, using AnyDVD HD I have got the .mt2s file. I have then used tsMuxer.GUI to demux to .dts hd file on its own.
    Here is the bit Im stuck at. Im using eac3to. Here are two links to screen shots of what Im looking at:
    http://img156.imageshack.us/img156/7665/62124296.jpg
    http://img156.imageshack.us/img156/5894/59310781.jpg
    Where abouts do I add in .dts file I wish to input? Are my links for tsMuxer.GUI and eac3to correct? On the second screen shot what options do I need to choose to get the .dts to be converted to AC3?
    Lastly do I need "Sonic Cinemaster Audio Decoder" installed?
    Thanks loads for reading.
  2. Member midders's Avatar
    eac3to is simple to use from the command line:
    eac3to.exe "input.dts" "output.ac3" -448
    Slainte
    midders
    P.S. eac3to will use the best available decoder; if you don't have Sonic etc. it will use libav
