I have a bunch of MKV files that I wanted to convert but I'm getting stumped. According to VLC player, the video track is using avc1 and they play fine with ffdshow video decoder.
But I wanted to cut segment for making animated gif.
virtualdubmod can open it but it displays blank so I couldn't tell where to start and end, and can only do direct stream copy because it doesn't understand codec "yyyy" (with funny symbol over the top) and tells me I need to install codec first. I checked google, ffdshow is supposed to cover this si I guess ffdshow and virtualdubmod doesn't play nice with each other.
I tried Dr. DivX and it claimed I didn't have the latest DivX installed and flat out refused to run. I checked, and I already have the latest version. I think Dr. DivX was last updated before DivX 7 came out and Dr. DivX erroneously assumed DivX 7 is not the latest version.
I tried WinAVIVideo COnverter and despite its claim it can convert anything to anything, it also failed. I select anything to avi, set the source file and destination, and video size. Then it process, and was done in just a second. No file was ever created. Good thing I only tried the trial version as it would have been a waste of my money to have program that doesn't work.
I am going crazy. What will work on converting a mkv file with avc1 codec to something that virtualdub(mod) will understand??
Try AVI DeMux?
you can use latest virtualdub version 1.9.x with the directshow input plugin should work as long as your mkv plays on windows media player. search for it in these forums
VirtualDubMod's MKV support is very old and out of date. Don't expect it to open any recent MKV files directly unless it created them itself. You can always use the DirectShowSource template (at the bottom of the Open File dialog) if you have a DirectShow MKV splitter and decoders installed.
jagabo- virtualdub 1.9.x still don't support mkv.
olyteddy- AVIDemux worked better, it had option to "Save Selection as JPEG images..."
Skip converting, skip using virtualdub.
Thank you!!
I didn't say it did. Although it does indirectly via DirectShow.Originally Posted by impmon2
Where to get the AVC1 codec to play .mp4 videos?
By TyLord in forum Newbie / General discussionsReplies: 25Last Post: 15th May 2011, 21:29 -
Cannot display or convert video that uses AVC1 codec?
By peggypwr1 in forum Newbie / General discussionsReplies: 12Last Post: 4th May 2011, 04:19 -
VirtualDubMod crashed on me while opening an MKV file
By The Monarch in forum Newbie / General discussionsReplies: 2Last Post: 5th Oct 2009, 06:57 -
error when opening up mkv file with virtualdubmod
By parth82390 in forum Video ConversionReplies: 5Last Post: 5th Dec 2007, 18:00 -
Cutting/Stream-copying AVC1/AC3 inside MKV
By honeyko in forum EditingReplies: 0Last Post: 1st Nov 2007, 21:14
