Results 1 to 10 of 10
    hello im a total noob to this so here goes,, i have searched the net but cant seem to find an exact answer ? i have a medion cam corder 80324 which has a built in digital signal processor i guess this means it will change to mpeg or similar file ?.. it has s video 4 pin port and also a av output with a scart that goes to tv . my problem is im trying to get from the tape to dvd using my computer , i have firewire ports included on my pc . can i buy such a lead that goes from svid to firwire or av to firewire ? would this work as the signal has been converted with the processor on the cam corder or am i thinkin wrong and can i even buy such a lead ?? or do i need to run the cam into something like moviebox dv or dazzle . please help thanks
    i have looked into buying a dvd recorder and am aware of this option but i wanto be able to edit an author
  2. If the camera does not have firewire out, then you will need some sort of capture device. Many ways to do this, the DVD recorder is probably easiest and the output can be edited on the PC.
  3. Member edDV's Avatar
    You will need an analog S-Video to DV converter. Among the recommended options...
    1. A MiniDV or Digital8 camcorder with "analog pass through" to DV feature.
    2. Canopus ADVC converter (serveral models)
    3. ADS Pyro DV converter
    The DV Moviebox and older Sony converters are not recommended.
    Or, you can capture S-Video to a DVD recorder or conventional computer capture card.
    Also, some Digital8 camcorders will play Video8 or Hi8 analog tapes with DV output over Firewire.
    http://www.kiva.org/about
    You can play from the camera into a DVD recorder or any capture card. DV not required (and not suggested, to be honest).
    Dazzle Video Creator Plus
    Video inputs: Composite video (RCA), S-Video (mini-DIN)
    Audio inputs: Stereo audio (RCA x2)
    PC connection: Hi-Speed USB 2.0
    thanks .. what about roxio's easy vhs to dvd ?? looks simple an cheap enuff ?? although it use's a usb ?/ not to sure if thats a bad thing ??
  7. Member edDV's Avatar
    What would you use for a capture device? Hi8 camcorders don't have usb. They are analog S-video out.
    no it has audio to usb check this http://www.roxio.co.uk/eng/products/...FdBb4wodjmKFLw
    it just plugs into the av jack on my cam corder ?/
    but does usb reduce quality
    reviews arent over whelming for this product it seems !!
    I use the ADS Pyro for analog sources. Works great. When not capturing from those devices, I use it to output the an external monitor while working in Premiere. Whatever I am playing/scrubbing, then also goes to the external video monitor.
    Since my computer has 3 Firewire inputs, I connect my digital sources directly to one of the other ports.
  1. Replies: 30
    Last Post: 19th Jan 2010, 23:51
  2. hi 8 tapes to dvd ?? help
    By daviey boy in forum Newbie / General discussions
    Last Post: 5th Nov 2009, 09:01
  3. I need to transfer my miniDV and old hi8 tapes tapes to dvd
    By bryanport in forum DVD & Blu-ray Recorders
    Last Post: 4th Oct 2007, 20:19
  4. Solid Blue lines in Mini DV tapes... camcorder infected all tapes for 3 yrs
    By samiandsky in forum Newbie / General discussions
    Last Post: 2nd Feb 2007, 12:01
  5. How to convert DV tapes to DVD?
    By ashvar in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 18th Jan 2006, 14:09
About   Advertise   Forum   RSS Feeds   Statistics   Tools
